数据:
WL18xxMOD WiLink 8 单频段 Combo模块 – Wi-Fi, Bluetooth,和 Bluetooth 低功耗 (BLE) 数据表 (Rev. J)
TI经认证的WiLink 8模块采用功率优化设计,可提供高数据吞吐量和扩展范围,并且支持Wi-Fi和共存(只适用于WL1835MOD).WL18x5MOD器件是一套2.4GHz模块双天线解决方案。该器件经FCC,IC,ETSI /CE和TELEC认证,适用于接入点(AP)和客户端.TI为Linux,Android,WinCE和RTOS等高级操作系统提供了驱动程序。
| Device Type |
| Flash (KB) |
| Throughput (Max) (Mbps) |
| Features |
| Operating Temperature Range (C) |
| Certifications |
| Package (mm) |
| WL1831MOD | WL1801MOD | WL1805MOD | WL1807MOD | WL1835MOD | WL1837MOD |
| Module Smart RF Transceiver | Module Smart RF Transceiver | Module Smart RF Transceiver | Smart RF Transceiver | Module Smart RF Transceiver | Module Smart RF Transceiver |
| N/A | N/A | N/A | N/A | N/A | N/A |
| 100 | 100 | 100 | 100 | 100 | 100 |
| 802.11bgn Bluetooth 4.2 AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s | 802.11bgn AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s | 802.11bgn 2x2 MIMO AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s | 802.11abgn 2x2 MIMO AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s | 802.11bgn Bluetooth 4.2 2x2 MIMO AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s | 02.11abgn Bluetooth 4.2 2x2 MIMO AP STA Wi-Fi Direct Mode Mesh over Wi-Fi based on 802.11s |
| -20 to 70 | -20 to 70 | -20 to 70 | -40 to 85 | -20 to 70 | -40 to 85 |
| FCC, IC, ETSI/CE, and TELEC | FCC, IC, ETSI/CE, and TELEC | FCC, IC, ETSI/CE, and TELEC | FCC, IC, ETSI/CE, and TELEC | FCC, IC, ETSI/CE, and TELEC | FCC, IC, ETSI/CE, and TELEC |
| MOC (100 pin LGA Module) | MOC (100 pin LGA Module) | MOC (100 pin LGA Module) | MOC (100 pin LGA Module) | MOC (100 pin LGA Module) | MOC (100 pin LGA Module) |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
