数据:
四通道,250 每秒百万次采样(MSPS) 接收器和反馈模数转换器(ADC) 数据表 (Rev. B)
ADS58H40是一款高线性,四通道,14位,250MSPS模数转换器(ADC)。四个ADC通道被分成两块,每个块有两个ADC。每个块可被独立配置成为三个不同的运行模式。一个运行模式包括SNRBoost 3G + 信号处理技术的实现来在只使用11位分辨率的情况下在高达
90MHz带宽内提供高信噪比(SNR)。针对低功耗和高无杂散动态范围(SFDR)而设计,此ADC具有低噪声性能以及在宽输入频率范围内出色的SFDR 。
所有商标均归其所有专营业主。
| # Input Channels |
| Resolution (Bits) |
| Sample Rate (Max) (MSPS) |
| Features |
| Analog Input BW (MHz) |
| SFDR (Typ) (dB) |
| SNR (Typ) (dB) |
| Power Consumption (Typ) (mW) |
| Logic Voltage DV/DD (Max) (V) |
| Logic Voltage DV/DD (Min) (V) |
| Analog Voltage AVDD (Max) (V) |
| Analog Voltage AVDD (Min) (V) |
| Operating Temperature Range (C) |
| Pin/Package |
| ADS58H40 | ADS58H43 | ADS58J89 |
| 4 | 4 | 4 |
| 14 | 14 | 14 |
| 250 | 250 | 500 |
| Decimating Filter Differential Inputs High Dynamic Range Nap Mode Out of Range Indicator Power Down | Decimating Filter Differential Inputs High Dynamic Range Nap Mode Out of Range Indicator Power Down | Decimating Filter Differential Inputs High Dynamic Range Nap Mode Out of Range Indicator Power Down |
| 500 | 500 | 900 |
| 85 | 85 | 85 |
| 71 | 70.5 | 65.8 |
| 1460 | 1460 | 3270 |
| 2 | 2 | 1.9 |
| 1.7 | 1.7 | 1.7 |
| 3.45 | 3.45 | 2 |
| 1.8 | 1.8 | 1.8 |
| -40 to 85 | -40 to 85 | -40 to 85 |
| 144NFBGA | 144NFBGA | 64VQFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
