一段ESP32S2代码
 * SPDX-FileCopyrightText: 2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
#include "esp_check.h"
#include "led_strip_rmt_encoder.h"
static const char *TAG = "led_rmt_encoder";
typedef struct {
    rmt_encoder_t base;
    rmt_encoder_t *bytes_encoder;
    rmt_encoder_t *copy_encoder;
    int state;
    rmt_symbol_word_t reset_code;
} rmt_led_strip_encoder_t;
static size_t rmt_encode_led_strip(rmt_encoder_t *encoder, rmt_channel_handle_t channel, const void *primary_data, size_t data_size, rmt_encode_state_t *ret_state)
    rmt_led_strip_encoder_t *led_encoder = __containerof(encoder, rmt_led_strip_encoder_t, base);
    rmt_encoder_handle_t bytes_encoder = led_encoder->bytes_encoder;
    rmt_encoder_handle_t copy_encoder = led_encoder->copy_encoder;
    rmt_encode_state_t session_state = 0;
    rmt_encode_state_t state = 0;
    size_t encoded_symbols = 0;
    switch (led_encoder->state) {
    case 0: // send RGB data
        encoded_symbols += bytes_encoder->encode(bytes_encoder, channel, primary_data, data_size, &session_state);
        if (session_state & RMT_ENCODING_COMPLETE) {
            led_encoder->state = 1; // switch to next state when current encoding session finished
        if (session_state & RMT_ENCODING_MEM_FULL) {
            state |= RMT_ENCODING_MEM_FULL;
            goto out; // yield if there's no free space for encoding artifacts
    // fall-through
    case 1: // send reset code
        encoded_symbols += copy_encoder->encode(copy_encoder, channel, &led_encoder->reset_code,
                                                sizeof(led_encoder->reset_code), &session_state);
            led_encoder->state = 0; // back to the initial encoding session
            state |= RMT_ENCODING_COMPLETE;
out:
    *ret_state = state;
    return encoded_symbols;
static esp_err_t rmt_del_led_strip_encoder(rmt_encoder_t *encoder)
    rmt_del_encoder(led_encoder->bytes_encoder);
    rmt_del_encoder(led_encoder->copy_encoder);
    free(led_encoder);
    return ESP_OK;
static esp_err_t rmt_led_strip_encoder_reset(rmt_encoder_t *encoder)
    rmt_encoder_reset(led_encoder->bytes_encoder);
    rmt_encoder_reset(led_encoder->copy_encoder);
    return ESP_OK;
esp_err_t rmt_new_led_strip_encoder(const led_strip_encoder_config_t *config, rmt_encoder_handle_t *ret_encoder)
    esp_err_t ret = ESP_OK;
    rmt_led_strip_encoder_t *led_encoder = NULL;
    ESP_GOTO_ON_FALSE(config && ret_encoder, ESP_ERR_INVALID_ARG, err, TAG, "invalid argument");
    ESP_GOTO_ON_FALSE(config->led_model < LED_MODEL_INVALID, ESP_ERR_INVALID_ARG, err, TAG, "invalid led model");
    led_encoder = calloc(1, sizeof(rmt_led_strip_encoder_t));
    ESP_GOTO_ON_FALSE(led_encoder, ESP_ERR_NO_MEM, err, TAG, "no mem for led strip encoder");
    led_encoder->base.encode = rmt_encode_led_strip;
    led_encoder->base.del = rmt_del_led_strip_encoder;
    led_encoder->base.reset = rmt_led_strip_encoder_reset;
    rmt_bytes_encoder_config_t bytes_encoder_config;
    uint32_t reset_ticks = config->resolution / 1000000 * 280 / 2; // reset code duration defaults to 280us to accomodate WS2812B-V5
    if (config->led_model == LED_MODEL_SK6812) {
        bytes_encoder_config = (rmt_bytes_encoder_config_t) {
            .bit0 = {
                .level0 = 1,
                .duration0 = 0.3 * config->resolution / 1000000, // T0H=0.3us
                .level1 = 0,
                .duration1 = 0.9 * config->resolution / 1000000, // T0L=0.9us
            .bit1 = {
                .level0 = 1,
                .duration0 = 0.6 * config->resolution / 1000000, // T1H=0.6us
                .level1 = 0,
                .duration1 = 0.6 * config->resolution / 1000000, // T1L=0.6us
            .flags.msb_first = 1 // SK6812 transfer bit order: G7...G0R7...R0B7...B0(W7...W0)
    } else if (config->led_model == LED_MODEL_WS2812) {
        // different led strip might have its own timing requirements, following parameter is for WS2812
            .bit0 = {
                .level0 = 1,
                .level1 = 0,
            .bit1 = {
                .level0 = 1,
                .duration0 = 0.9 * config->resolution / 1000000, // T1H=0.9us
                .level1 = 0,
                .duration1 = 0.3 * config->resolution / 1000000, // T1L=0.3us
            .flags.msb_first = 1 // WS2812 transfer bit order: G7...G0R7...R0B7...B0
    } else if (config->led_model == LED_MODEL_WS2811) {
        // different led strip might have its own timing requirements, following parameter is for WS2811
            .bit0 = {
                .level0 = 1,
                .duration0 = 0.5 * config->resolution / 1000000., // T0H=0.5us
                .level1 = 0,
                .duration1 = 2.0 * config->resolution / 1000000., // T0L=2.0us
            .bit1 = {
                .level0 = 1,
                .duration0 = 1.2 * config->resolution / 1000000., // T1H=1.2us
                .level1 = 0,
                .duration1 = 1.3 * config->resolution / 1000000., // T1L=1.3us
        reset_ticks = config->resolution / 1000000 * 50 / 2; // divide by 2... signal is sent twice
    } else {
        assert(false);
    ESP_GOTO_ON_ERROR(rmt_new_bytes_encoder(&bytes_encoder_config, &led_encoder->bytes_encoder), err, TAG, "create bytes encoder failed");
    rmt_copy_encoder_config_t copy_encoder_config = {};
    ESP_GOTO_ON_ERROR(rmt_new_copy_encoder(©_encoder_config, &led_encoder->copy_encoder), err, TAG, "create copy encoder failed");
    led_encoder->reset_code = (rmt_symbol_word_t) {
        .level0 = 0,
        .duration0 = reset_ticks,
        .level1 = 0,
        .duration1 = reset_ticks,
    *ret_encoder = &led_encoder->base;
    return ESP_OK;
err:
    if (led_encoder) {
        if (led_encoder->bytes_encoder) {
        if (led_encoder->copy_encoder) {
        free(led_encoder);
    return ret;
