在电子工程师的日常设计工作中,固态继电器是一种常见且关键的组件。今天,我们要深入探讨的是Littelfuse公司的CPC2501M电压控制非隔离固态继电器,它在众多应用场景中展现出了独特的优势。
文件下载:Littelfuse CPC2501M固态继电器.pdf
CPC2501M是一款电压控制、常闭型的60V、1.84A固态继电器。它采用了内部控制电路,具备自驱动能力和故障保护定时器等特性。其小巧的6×6 [mm]热增强QFN封装,在节省空间的同时,也为散热提供了良好的条件。
| CPC2501M共有16个引脚,不同引脚承担着不同的功能。例如,VIN为电源输入引脚,接收来自二极管桥的正全波整流电压;Vss为电源返回引脚;VDD为调节后的电源输出引脚,为内部电路供电。详细的引脚定义如下表所示: | Pin | Name | Type | Description |
| 1 | VIN | Power | Supply voltage. Positive full wave rectified voltage from diode bridge | |
| 2 | Vss | Power | Supply voltage return. Negative voltage from diode bridge | |
| 3 | VDD | Output | Regulated supply voltage or internal circuitry, Connect capacitor from Voo to Vss' | |
| 4 | DNU1 | Do Not Use: Connect to Vo | ||
| 5 | DNU2 | Do Not Use: Connect to Vsss | ||
| 6 | DNC | 一 | Do Not Connect: Do not connect this pin. | |
| 7 | N/C | No Connection: Not internally connected. | ||
| 8,9,10 | SW1 | 1/O | Switch terminal 1 | |
| 11,12,13 | SW2 | 1/O | Switch terminal 2 | |
| 14 | N/C | No Connection: Not internally connected. | ||
| 15 | TOP | Output | Envelope tracking voltage of Vin Connect capacitor from TOP to Vss'" | |
| 16 | PK | Output | Peak voltage of VinN Connect capacitor from PK to Vss. | |
| EP1 | SW1 | Thermal | Thermal pad for SW1 power MOSFET. Connect to SW1, pins 8, 9 and 10.2 | |
| EP2 | SW2 | Thermal | Thermal pad for SW2 power MOSFET. Connect to SW2, pins 11, 12 and 13.2 | |
| EP3 | DNC | Thermal | Thermal pad for the Control IC. Do not connect to this pad.2 |
| 在使用CPC2501M时,必须严格遵守其绝对最大额定值,否则可能会对器件造成永久性损坏。例如,VIN、VPK、VTOP的电压范围为 - 0.3V至 + 60V,开关峰值负载电流(t < 16ms)为5A等。具体参数如下表: | Parameter | Rating | Unit |
| VINe VPK VTOP | -0.3 to +60 | V | |
| SW1 to SW2 | -60 to+60 | V | |
| Voo. DNU1, DNU2 | -0.3 to +5.5 | V | |
| Switch Peak Load Current (L) (fort<16ms) | 5 | A | |
| Total Power Dissipation | 2.5 | W | |
| ESD Rating,Human Body Model | ±2 | kV | |
| AmbientTmperature (T | -40to+85 | ℃ | |
| Virtual Junction Temperature (T) | +125 | ℃ | |
| Storage Temperature (Tstg) | -40 to +150 | ℃ |
为了确保CPC2501M的最佳性能,推荐的工作条件为VinN至Vss的电压为44V,开关负载电流为1.84A RMS。
| 热特性对于固态继电器的性能和可靠性至关重要。CPC2501M的热阻参数如下: | Parameter | Symbol Rating | Units | |
| Thermal Impedance, Junction to Air | 日城 | 40 | °C/ | |
| Thermal Impedance, Junction to Case | 0 JC | 3 | ℃C/W |
需要注意的是,这些热阻参数是基于特定的PCB设计测量得到的,在实际应用中,可能需要根据具体情况进行调整。
电气特性反映了CPC2501M在不同条件下的性能表现。例如,输入电流、输入电压激活阈值、激活到开关打开延迟等参数。这些参数在不同的输入电压和电容条件下会有所变化,工程师在设计时需要根据实际需求进行选择。
CPC2501M由多个功能模块组成,每个模块都发挥着重要的作用。
在典型的视频门铃应用中,CPC2501M的工作原理如下:
CPC2501M的湿度敏感性等级为MSL1,在使用过程中,需要按照IPC/JEDEC J - STD - 033标准进行处理,以防止因湿气侵入导致产品性能下降。
该产品对静电放电(ESD)敏感,应按照行业标准JESD - 625进行操作,避免因静电损坏器件。
在回流焊接过程中,CPC2501M的分类温度为260°C,最大停留时间为30秒,最大回流次数为3次。工程师需要严格控制焊接参数,确保焊接质量。
Littelfuse推荐使用免清洗助焊剂配方。在回流焊接后进行电路板清洗时,需要采取适当的预防措施,如使用低压清洗、后续烘烤等,以防止器件损坏。同时,应避免使用超声波清洗和卤化物助焊剂或溶剂。
文档提供了CPC2501M的详细机械尺寸,包括16引脚QFN封装尺寸、推荐焊盘尺寸和卷带尺寸等。这些尺寸信息对于PCB设计和器件安装非常重要,工程师需要根据实际情况进行合理布局。
CPC2501M电压控制非隔离固态继电器凭借其丰富的特性和广泛的应用领域,为电子工程师在设计过程中提供了更多的选择。在实际应用中,工程师需要根据具体的设计需求,合理选择器件参数,严格遵守制造信息中的要求,以确保电路的性能和可靠性。同时,我们也可以思考如何进一步优化CPC2501M在不同应用场景中的性能,发挥其最大的潜力。你在使用固态继电器的过程中,遇到过哪些问题呢?欢迎在评论区分享你的经验和见解。
