TRF370317 0.4GHz 至 4.0GHz 正交调制器,1.7V 共模电压
KANA 发表于 2018-11-02 19:27:06
数据: 0.4 GHz to 4-GHz Quadrature Modulator 数据表
The TRF370317 is a low-noise direct quadrature modulator, capable of converting complex modulated signals from baseband or IF directly up to RF. The TRF370317 is a high-performance, superior-linearity device that is ideal to RF frequencies of 400 MHz through 4 GHz. The modulator is implemented as a double-balanced mixer. The RF output block consists of a differential to single-ended converter and an RF amplifier capable of driving a single-ended 50- load without any need of external components. The TRF370317 requires a 1.7-V common-mode voltage for optimum linearity performance.
特性
  • 76-dBc单载波WCDMA ACPR,-8 dBm信道功率
  • 低噪声基底:-163 dBm /Hz
  • OIP3为26.5 dBm
  • P1dB为12 dBm
  • 未调整载波馈通-40 dBm
  • 未调整的边带抑制-45 dBc
  • 单电源:4.5 V-5.5 V工作
  • 硅锗技术
  • I,Q基带输入的1.7 V CM
  • 应用
    • 蜂窝基站收发器
    • CDMA:IS95,UMTS,CDMA2000,TD-SCDMA
    • TDMA:GSM,IS-136,EDGE /UWC-136
    • Multicarrier GSM
    • WiMAX:802.16d /e
    • 3GPP:LTE
    • 无线城域网宽带收发器
参数 与其它产品相比 IQ 调制器
Frequency (Min) (MHz)
Frequency (Max) (MHz)
I/Q Input Common-Mode Voltage (Typ)
PLL/VCO
P1dB (Typ) (dBm)
Output IP3 (Typ) (dBm)
Noise Floor (Typ) (dBm/Hz)
Unadjusted Carrier Suppression (Typ) (dBm)
Unadjusted Sideband Suppression (Typ) (dBc)
Supply (V)
Package Group
Package Size: mm2:W x L (PKG)
Pin/Package
TRF370317 TRF370315 TRF370333 TRF370417 TRF3705 TRF37T05
400     350     350     50     300     300
4000     4000     4000     6000     4000     4000
1.7     1.5     3.3     1.7     0.25     0.25
No     No     No     No     No     No
12     9     9     12     13     13
26.5     23     23     26.5     30     30
-163     -163     -163     -162     -160     -160
-40     -40     -40     -38     -45     -45
-45     -40     -40     -50     -45     -45
5     5     5     5     3.3     3.3
VQFN     VQFN     VQFN     VQFN     VQFN     VQFN
24VQFN: 16 mm2: 4 x 4(VQFN)     24VQFN: 16 mm2: 4 x 4(VQFN)     24VQFN: 16 mm2: 4 x 4(VQFN)     24VQFN: 16 mm2: 4 x 4(VQFN)     24VQFN: 16 mm2: 4 x 4(VQFN)     24VQFN: 16 mm2: 4 x 4(VQFN)
24VQFN     24VQFN     24VQFN     24VQFN     24VQFN     24VQFN
方框图 (1)
技术文档
数据手册(1)
收藏
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
