此单缓冲器/驱动器设计用于1.65 V至5.5 VV CC 操作。
SN74LVC1G07器件的输出为漏极开路,可连接到其他漏极开路输出,以实现低电平有效或高电平有线和功能。最大灌电流为32 mA。
该器件完全适用于使用I off 的部分断电应用。 I off 电路禁用输出,防止在断电时损坏通过器件的电流回流。
(1)符合JEDEC和工业的组件资格符合标准,确保在扩展温度范围内可靠运行。这包括但不限于高加速应力测试(HAST)或偏压85/85,温度循环,高压釜或无偏HAST,电迁移,键合金属间寿命和模塑化合物寿命。此类鉴定测试不应被视为超出规定的性能和环境限制使用该组件的合理性。
| Technology Family |
| Sub-Family |
| Gate Type |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Bits (#) |
| Voltage (Nom) (V) |
| F @ Nom Voltage (Max) (Mhz) |
| ICC @ Nom Voltage (Max) (mA) |
| tpd @ Nom Voltage (Max) (ns) |
| IOL (Max) (mA) |
| Input Type |
| Output Type |
| Logic |
| 3-State Output |
| Schmitt Trigger |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| SN74LVC1G07-EP | SN74LVC1G00 | SN74LVC1G02 | SN74LVC1G04 | SN74LVC1G04-EP | SN74LVC1G04-Q1 | SN74LVC1G07 | SN74LVC1G07-Q1 | SN74LVC1G08 | SN74LVC1G08-EP | SN74LVC1G08-Q1 | SN74LVC1G17 | SN74LVC1G17-EP | SN74LVC1G17-Q1 | SN74LVC1G32 | SN74LVC1G32-EP | SN74LVC1G32-Q1 | SN74LVC1G34 |
| LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC |
| Non-Inverting Buffer/Driver | NAND Gate | NOR Gate | Inverting Buffer/Driver | Inverting Buffer/Driver | Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | AND Gate | AND Gate | AND Gate | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | OR Gate | OR Gate | OR Gate | Non-Inverting Buffer/Driver |
| OPEN DRAIN BUFFER | NAND | NOR | INVERTER BUFFER | INVERTER BUFFER | INVERTER BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | AND | AND | AND | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | OR | OR | OR | BUFFER |
| 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 6.5 | 6.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 |
| 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 |
| 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.02 | 0.01 | 0.01 | 0.025 | 0.001 |
| 5.7 4.9 | 9 5.5 4.7 4 | 8 5.5 4.5 4 | 7.5 5.2 4.2 3.7 | 13.9 8 5.7 4.5 | 7.5 5.2 4.2 3.7 | 8.6 6 4.7 4 | 9.8 7 5.7 4.9 | 4.5 6 4 5 | 8 5.5 4.5 4 | 8 5.5 4.5 4 | 11 6.5 5.5 5 | 11 6.5 5.5 5 | 14 9 8 7 | 7.2 4.4 3.6 3.4 | 8 6.5 5.7 4.5 | 11 7.5 6.5 6 | 8.6 4.4 4.1 3.2 |
| 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 24 | 32 | 32 | 32 | 32 | 32 | 32 |
| CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS Open-Drain | CMOS Open-Drain | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
| True | True | True | Inverting | Inverting | Inverting | True | True | True | True | True | True | True | True | True | True | True | True |
| No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| No | No | No | No | No | No | No | No | No | No | No | Yes | Yes | Yes | No | No | No | No |
| HiRel Enhanced Product | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog |
| -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 |
| SC70 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON |
| 5SC70: 4 mm2: 2.1 x 2(SC70) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
