数据:
Single Schmitt-Trigger Buffer 数据表
此单施密特触发器缓冲器设计用于1.65 V至5.5 VV CC 操作。
SN74LVC1G17包含一个缓冲器并执行布尔函数Y = A.器件用作独立缓冲器,但由于施密特操作,它可能具有不同的正向输入阈值电平(V T + )和负向(V T - )信号。
NanoStar™和NanoFree™封装技术是IC封装概念的一项重大突破,使用裸片作为封装。 /p>
使用I off 为部分断电应用完全指定了该器件。 I off 电路禁用输出,防止在断电时损坏通过器件的电流回流。
(1)符合JEDEC和行业标准的元件认证,确保在扩展温度范围内可靠运行。这包括但不限于高加速应力测试(HAST)或偏压85/85,温度循环,高压釜或无偏HAST,电迁移,键合金属间寿命和模塑化合物寿命。此类鉴定测试不应视为超出规定性能和环境限制使用此组件的合理性。
NanoStar,NanoFree是德州仪器公司的商标。
| Technology Family |
| Sub-Family |
| Gate Type |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Bits (#) |
| Voltage (Nom) (V) |
| F @ Nom Voltage (Max) (Mhz) |
| ICC @ Nom Voltage (Max) (mA) |
| tpd @ Nom Voltage (Max) (ns) |
| IOL (Max) (mA) |
| Input Type |
| Output Type |
| Logic |
| 3-State Output |
| Schmitt Trigger |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| SN74LVC1G17-EP | SN74LVC1G00 | SN74LVC1G02 | SN74LVC1G04 | SN74LVC1G04-EP | SN74LVC1G04-Q1 | SN74LVC1G07 | SN74LVC1G07-EP | SN74LVC1G07-Q1 | SN74LVC1G08 | SN74LVC1G08-EP | SN74LVC1G08-Q1 | SN74LVC1G17 | SN74LVC1G17-Q1 | SN74LVC1G32 | SN74LVC1G32-EP | SN74LVC1G32-Q1 | SN74LVC1G34 |
| LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC |
| Non-Inverting Buffer/Driver | NAND Gate | NOR Gate | Inverting Buffer/Driver | Inverting Buffer/Driver | Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | AND Gate | AND Gate | AND Gate | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | OR Gate | OR Gate | OR Gate | Non-Inverting Buffer/Driver |
| SCHMITT TRIGGER BUFFER | NAND | NOR | INVERTER BUFFER | INVERTER BUFFER | INVERTER BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | AND | AND | AND | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | OR | OR | OR | BUFFER |
| 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 |
| 6.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 6.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 |
| 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 |
| 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.02 | 0.01 | 0.01 | 0.025 | 0.001 |
| 11 6.5 5.5 5 | 9 5.5 4.7 4 | 8 5.5 4.5 4 | 7.5 5.2 4.2 3.7 | 13.9 8 5.7 4.5 | 7.5 5.2 4.2 3.7 | 8.6 6 4.7 4 | 5.7 4.9 | 9.8 7 5.7 4.9 | 4.5 6 4 5 | 8 5.5 4.5 4 | 8 5.5 4.5 4 | 11 6.5 5.5 5 | 14 9 8 7 | 7.2 4.4 3.6 3.4 | 8 6.5 5.7 4.5 | 11 7.5 6.5 6 | 8.6 4.4 4.1 3.2 |
| 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 24 | 32 | 32 | 32 | 32 | 32 |
| CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS Open-Drain | CMOS | CMOS Open-Drain | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
| True | True | True | Inverting | Inverting | Inverting | True | True | True | True | True | True | True | True | True | True | True | True |
| No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| Yes | No | No | No | No | No | No | No | No | No | No | No | Yes | Yes | No | No | No | No |
| HiRel Enhanced Product | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog |
| -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 |
| SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
