SN74LVC1G08执行布尔函数Y = A ??正逻辑中的B或Y = A \ + B \ 。
此设备完全为使用I的部分断电应用指定<子>关子>。 I off 电路禁用输出,防止在断电时损坏通过器件的电流回流。
(1)组件认证符合JEDEC和行业标准,确保可靠运行扩展的温度范围。这包括但不限于高加速应力测试(HAST)或偏压85/85,温度循环,高压釜或无偏HAST,电迁移,键合金属间寿命和模塑化合物寿命。此类鉴定测试不应被视为超出规定的性能和环境限制使用该组件的合理性。
| Technology Family |
| Sub-Family |
| Gate Type |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Bits (#) |
| Voltage (Nom) (V) |
| F @ Nom Voltage (Max) (Mhz) |
| ICC @ Nom Voltage (Max) (mA) |
| tpd @ Nom Voltage (Max) (ns) |
| IOL (Max) (mA) |
| Input Type |
| Output Type |
| Logic |
| 3-State Output |
| Schmitt Trigger |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| SN74LVC1G08-EP | SN74LVC1G00 | SN74LVC1G02 | SN74LVC1G04 | SN74LVC1G04-EP | SN74LVC1G04-Q1 | SN74LVC1G07 | SN74LVC1G07-EP | SN74LVC1G07-Q1 | SN74LVC1G08 | SN74LVC1G08-Q1 | SN74LVC1G17 | SN74LVC1G17-EP | SN74LVC1G17-Q1 | SN74LVC1G32 | SN74LVC1G32-EP | SN74LVC1G32-Q1 | SN74LVC1G34 |
| LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC |
| AND Gate | NAND Gate | NOR Gate | Inverting Buffer/Driver | Inverting Buffer/Driver | Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | AND Gate | AND Gate | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | OR Gate | OR Gate | OR Gate | Non-Inverting Buffer/Driver |
| AND | NAND | NOR | INVERTER BUFFER | INVERTER BUFFER | INVERTER BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | AND | AND | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | OR | OR | OR | BUFFER |
| 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 6.5 | 6.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 |
| 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 |
| 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.02 | 0.01 | 0.01 | 0.025 | 0.001 |
| 8 5.5 4.5 4 | 9 5.5 4.7 4 | 8 5.5 4.5 4 | 7.5 5.2 4.2 3.7 | 13.9 8 5.7 4.5 | 7.5 5.2 4.2 3.7 | 8.6 6 4.7 4 | 5.7 4.9 | 9.8 7 5.7 4.9 | 4.5 6 4 5 | 8 5.5 4.5 4 | 11 6.5 5.5 5 | 11 6.5 5.5 5 | 14 9 8 7 | 7.2 4.4 3.6 3.4 | 8 6.5 5.7 4.5 | 11 7.5 6.5 6 | 8.6 4.4 4.1 3.2 |
| 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 24 | 32 | 32 | 32 | 32 | 32 | 32 |
| CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS Open-Drain | CMOS | CMOS Open-Drain | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
| True | True | True | Inverting | Inverting | Inverting | True | True | True | True | True | True | True | True | True | True | True | True |
| No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| No | No | No | No | No | No | No | No | No | No | No | Yes | Yes | Yes | No | No | No | No |
| HiRel Enhanced Product | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog |
| -40 to 85 -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 |
| SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
