数据:
8-Pin Current Mode Push-Pull PWM ControllersWith Programmable Slope Compensation 数据表
UCC38083 /4/5/6是一系列BiCMOS脉宽调制(PWM)控制器,适用于DC-DC或离线固定 - 频率电流模式开关电源。双输出级配置为推挽式拓扑。两个输出均使用拨动触发器以振荡器频率的一半切换。两个输出之间的死区时间通常为110 ns,将每个输出的占空比限制在50%以内。
新的UCC3808x系列基于UCC3808A架构。主要区别包括为CS信号添加可编程斜率补偿斜坡和去除误差放大器。通过外部电阻流出ISET引脚的电流在内部进行监控,以设置斜率补偿功能的大小。该器件还包括一个从CS引脚到地的内部放电晶体管,在脉冲终止后的每个时钟周期激活该晶体管。这会在每个周期内释放CS引脚上的任何滤波器电容,并有助于最小化滤波电容值和电流检测延迟。
UCC38083和UCC38084器件的典型软启动间隔时间为3.5 ms,而UCC38085对于不需要内部软启动的应用,UCC38086的时间小于100μs。
UCC38083和UCC38085器件的开启/关闭阈值为12.5 V /8.3 V,而UCC38084则为UCC38086的开启/关闭阈值为4.3 V /4.1 V.每个器件均采用8引脚TSSOP(PW),8引脚SOIC(D)和8引脚PDIP(P)封装。
| Topology |
| Control Method |
| Vin (Min) (V) |
| Vin (Max) (V) |
| Frequency (Max) (kHz) |
| UVLO Thresholds On/Off (V) |
| Duty Cycle (Max) (%) |
| Gate Drive (Typ) (A) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Pin/Package |
| UCC38085 | UCC38083 | UCC38084 | UCC38086 |
| Boost Buck Half-Bridge Push-Pull | Boost Buck Half-Bridge Push-Pull | Boost Buck Half-Bridge Push-Pull | Boost Buck Half-Bridge Push-Pull |
| Current | Current | Current | Current |
| 8.3 | 8.3 | 4.1 | 8.3 |
| 15 | 15 | 15 | 15 |
| 1000 | 1000 | 1000 | 1000 |
| 12.5/8.3 | 12.5/8.3 | 4.3/4.1 | 4.3/4.1 |
| 50 | 50 | 50 | 50 |
| 1 | 1 | 1 | 1 |
| Current Limiting Multi-topology Programmable Slope Compensation Soft Start | Current Limiting Multi-topology Programmable Slope Compensation Soft Start | Current Limiting Multi-topology Programmable Slope Compensation Soft Start | Current Limiting Multi-topology Programmable Slope Compensation Soft Start |
| Catalog | Catalog | Catalog | Catalog |
| 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 |
| 8PDIP 8SOIC | 8PDIP 8SOIC | 8PDIP 8SOIC 8TSSOP | 8PDIP 8SOIC |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
