数据:
在标题中增加了“价值线系列”36V,单电源,SOT553,通用 运算放大器价值线系列 数据表 (Rev. D)
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| OPA2171 | OPA171 | OPA171-Q1 | OPA2171-Q1 | OPA4171 | OPA4171-Q1 |
| 2 | 1 | 1 | 2 | 4 | 4 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 36 | 36 | 36 | 36 | 36 | 36 |
| 3 | 3 | 3 | 3 | 3 | 3 |
| 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
| 0.475 | 0.475 | 0.475 | 0.475 | 0.475 | 0.475 |
| 14 | 14 | 14 | 14 | 14 | 14 |
| Catalog | Catalog | Automotive | Automotive | Catalog | Automotive |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| SOIC VSSOP VSSOP | SOIC SOT-23 SOT-5X3 | SOT-23 | SOIC VSSOP | SOIC TSSOP | SOIC TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 0.3 | 0.3 | 0.3 | 0.3 | 0.3 | 0.3 |
| EMI Hardened Small Size | EMI Hardened Small Size | EMI Hardened | EMI Hardened | EMI Hardened | EMI Hardened |
| 15 | 15 | 15 | 15 | 15 | 15 |
| 120 | 120 | 120 | 120 | 120 | 120 |
| 25 | 25 | 25 | 25 | 25 | 25 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
