数据:
2.7-V High-Slew-Rate Rail-to-Rail Output Op Amps w/ Shutdown 数据表
TLV277x CMOS运算放大器系列具有高压摆率和带宽,轨到轨输出摆幅,高输出驱动和出色的直流精度。该器件提供10.5 V /μs的压摆率和5.1 MHz的带宽,同时每通道仅消耗1 mA的电源电流。这种交流性能远高于目前竞争对手的CMOS放大器。轨到轨输出摆幅和高输出驱动使这些器件成为驱动模数转换器模拟输入或参考的理想选择。这些设备在驱动60000
负载时也具有低失真,可用于电信系统。
这些放大器具有360μV输入失调电压,17 nV /
Hz输入噪声电压,以及用于测量,医疗和工业应用的2 pA输入偏置电流。 TLV277x系列还可在扩展温度范围(-40°C至125°C)内使用,适用于汽车系统,军用温度范围(?? 55°C至125°C),适用于军事系统。
这些器件采用2.5 V至5.5 V单电源供电,工作电压为2.7 V和5 V.单电源供电和低功耗使这些器件成为便携式设备的理想解决方案。应用。下表列出了可用的软件包。
0.005%THD + N
Hz输入噪声电压| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TLV2771 | TLV2770 | TLV2771-Q1 | TLV2772 | TLV2772-Q1 | TLV2773 | TLV2774 | TLV2775 |
| 1 | 1 | 1 | 2 | 2 | 2 | 4 | 4 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 | 5.5 | 6 | 5.5 | 5.5 | 5.5 |
| 5.1 | 5.1 | 5.1 | 5.1 | 5.1 | 5.1 | 5.1 | 5.1 |
| 10.5 | 10.5 | 10.5 | 10.5 | 10.5 | 10.5 | 10.5 | 10.5 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 17 | 17 | 17 | 17 | 17 | 17 | 17 | 17 |
| Catalog | Catalog | Automotive | Catalog | Automotive | Catalog | Catalog | Catalog |
| -40 to 125 0 to 70 | -40 to 125 0 to 70 | -40 to 125 | -40 to 125 -55 to 125 0 to 70 | -40 to 125 | -40 to 125 0 to 70 | -40 to 125 0 to 70 | -40 to 125 0 to 70 |
| SOIC SOT-23 | PDIP SOIC VSSOP | SOT-23 | PDIP SOIC TSSOP VSSOP | SOIC TSSOP | SOIC VSSOP | PDIP SOIC TSSOP | PDIP SOIC TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| N/A | Shutdown | N/A | N/A | N/A | Shutdown | N/A | Shutdown |
| 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
| 96 | 96 | 96 | 96 | 96 | 96 | 96 | 96 |
| 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
