数据:
Family of Low-Power Wide Bandwidth Single Supply Op Amps with Shutdown 数据表
TLV262x单电源运算放大器提供轨到轨输出,输入范围包括正轨。 TLV262x在扩展的工业温度范围(?? 40°C至125°C)内将最低工作电源电压降至2.7 V,同时增加了轨到轨输出摆幅功能。 TLV262x还可在仅800μA的电源电流下提供11 MHz带宽。推荐的最大电源电压为5.5 V,当最小值为2.7 V时,可以使用锂离子电池工作。宽带宽,低噪声和低失真的组合使其成为高速和高分辨率数据转换器应用的理想选择。正输入范围允许它直接连接到正轨引用系统。所有器件均采用PDIP和SOIC封装,单通道采用小型SOT-23封装,双通道采用MSOP封装,四极采用TSSOP封装。
2.7V工作使其与锂离子电池兼容供电系统和许多微功率微控制器的工作电源电压范围,包括TI的MSP430。
Hz | Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TLV2620 | TLV2621 | TLV2622 | TLV2623 | TLV2624 |
| 1 | 1 | 2 | 2 | 4 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 11 | 11 | 11 | 11 | 11 |
| 6 | 6 | 6 | 6 | 6 |
| In to V+ Out | In to V+ Out | In to V+ Out | In to V+ Out | In to V+ Out |
| 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 53 | 53 | 53 | 53 | 53 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| SOIC SOT-23 | SOIC SOT-23 | SOIC VSSOP | VSSOP | SOIC TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 3 | 3 | 3 | 3 | 3 |
| Shutdown | N/A | N/A | Shutdown | N/A |
| 50 | 50 | 50 | 50 | 50 |
| 99 | 99 | 99 | 99 | 99 |
| 28 | 28 | 28 | 28 | 28 |
| CMOS | CMOS | CMOS | CMOS | CMOS |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
