数据:
TSM102A 数据表
TSM102和TMS102A结合了双运算放大器,双比较器和精密电压基准的构建模块,所有这些都经常用于实现各种电源管理功能,包括过流检测,欠压/过压检测,电源良好检测,窗口比较器,误差放大器等。其他应用包括报警和检测器/传感器应用。
TSM102A在25°C时,V REF 的严格公差为0.4%。 TSM102和TSM102A的工作温度范围为-40°C至85°C。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TSM102 | TSM102A | TSM104W | TSM104WA |
| 2 | 2 | 2 | 2 |
| 3 | 3 | 3 | 3 |
| 30 | 30 | 30 | 30 |
| 2.1 | 2.1 | 0.9 | 0.9 |
| 2 | 2 | 0.3 | 0.3 |
| In to V- | In to V- | In to V- | In to V- |
| 4.5 | 4.5 | 5 | 3 |
| 0.2 | 0.2 | 0.35 | 0.35 |
| 19 | 19 | 25 | 25 |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 105 | -40 to 105 |
| SOIC TSSOP | SOIC TSSOP | SOIC TSSOP | SOIC TSSOP |
| 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 10 | 10 | 7 | 7 |
| N/A | N/A | N/A | N/A |
| 100000 | 100000 | 150000 | 150000 |
| 90 | 90 | 85 | 85 |
| 6 | 6 | 40 | 40 |
| Bipolar | Bipolar | Bipolar | Bipolar |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
