ADS807,pdf(ADS807: 12-Bit, 53M
消耗积分:3 | 格式:rar | 大小:479 | 2010-06-06
分享资料个
The ADS807 is a high-speed, high dynamic range, 12-bit pipelined Analog-to-Digital (A/D) converter. This converter includes a high-bandwidth track-and-hold that gives excellent spurious performance up to and beyond the Nyquist rate. The differential nature of this track-and-hold and A/D converter circuitry minimizes even-order harmonics and gives excellent common-mode noise immunity. The track-and-hold can also be operated single-ended.
The ADS807 provides for setting the full-scale range of the converter without any external reference circuitry. The internal reference can be disabled allowing low drive, internal references to be used for improved tracking in multichannel systems.
The ADS807 provides an over-range indicator flag to indicate an input signal that exceeds the full-scale input range of the converter.
评论(0)
发评论
下载排行榜
