数据:
TL06xx Low-Power JFET-Input Operational Amplifiers 数据表
TL06x系列的JFET输入运算放大器设计为TL08x系列放大器的低功耗版本。它们具有高输入阻抗,宽带宽,高压摆率,低输入失调和输入偏置电流。 TL06x系列具有与TL07x和TL08x系列相同的端子分配。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TL062A | TL061 | TL061A | TL061B | TL062 | TL062B | TL064 | TL064A | TL064B |
| 2 | 1 | 1 | 1 | 2 | 2 | 4 | 4 | 4 |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
| 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ |
| 6 | 6 | 6 | 3 | 15 | 3 | 15 | 6 | 3 |
| 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
| 42 | 42 | 42 | 42 | 42 | 42 | 42 | 42 | 42 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | 0 to 70 |
| PDIP SO SOIC | PDIP SO SOIC | PDIP SOIC | PDIP | PDIP SO SOIC TSSOP | PDIP SOIC | PDIP SO SOIC TSSOP | PDIP SOIC | PDIP SOIC |
| See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) |
| 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
| Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps |
| 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
| 86 | 86 | 86 | 86 | 86 | 86 | 86 | 86 | 86 |
| FET | FET | FET | FET | FET | FET | FET | FET | FET |
| 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
