数据:
OPAx348 1MHz、45μA、CMOS 轨至轨
运算放大器 数据表 (Rev. H)
OPAx348系列放大器是单电源的低功耗CMOS运算放大器.OPAx348系列具有1MHz的扩展带宽和45μA的电源电流,适用于采用2.1V OPAx348系列具有45μA的低电源电流和0.5pA的输入偏置电流,因此是烟雾探测器及其他高阻抗传感器等低功耗应用的理想选择。
OPA348采用小型5引脚SC70(SOT),5引脚SOT-23(SOT)和8引脚SO(SOIC)封装.OPA2348采用8引脚SOT-23 (SOT)封装和8引脚SO(SOIC)封装,而OPA4348采用节省空间的14引脚TSSOP和14引脚SO(SOIC)封装。在全部电源范围内-40°C至+ 125°C的扩展温度范围提供了设计灵活性。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| OPA348 | OPA2348 | OPA2348-HIREL | OPA2348-Q1 | OPA4348 | OPA4348-Q1 |
| 1 | 2 | 2 | 2 | 4 | 4 |
| 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| In Out | In Out | In Out | In Out | In Out | In Out |
| 5 | 5 | 5 | 5 | 5 | 5 |
| 0.045 | 0.045 | 0.045 | 0.045 | 0.045 | 0.045 |
| 35 | 35 | 35 | 35 | 35 | 35 |
| Catalog | Catalog | Catalog | Automotive | Catalog | Automotive |
| -40 to 125 | -40 to 125 | 0 to 70 | -40 to 125 | -40 to 125 | -40 to 125 |
| SC70 SOIC SOT-23 | SOIC SOT-23 VSSOP | SOIC | SOIC TSSOP | TSSOP | |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | |
| 4 | 4 | 4 | 4 | 4 | 4 |
| Small Size | N/A | N/A | N/A | N/A | N/A |
| 10 | 10 | 10 | 10 | 10 | 10 |
| 82 | 82 | 82 | 82 | 82 | 82 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
| 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
