数据:
TL07xx 低噪声 JFET 输入运算放大器 数据表 (Rev. N)
TL07xx JFET输入运算放大器在单片集成电路中集成了匹配良好的高压JFET和双极晶体管。这些器件具有高压摆率,低输入偏置和失调电流以及低失调电压温度系数.TL07x系列的低谐波失真和低噪声等特性使其非常适合用于高保真和音频前置放大器应用.TL071器件具有失调引脚以支持外部输入失调校正。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TL072 | TL071 | TL074 | TL074A | TL074B |
| 2 | 1 | 4 | 4 | 4 |
| 7 | 7 | 7 | 7 | 7 |
| 36 | 36 | 36 | 36 | 36 |
| 3 | 3 | 3 | 3 | 3 |
| 13 | 13 | 13 | 13 | 13 |
| In to V+ | In to V+ | In to V+ | In to V+ | In to V+ |
| 6 | 6 | 6 | 6 | 3 |
| 1.4 | 1.4 | 1.4 | 1.4 | 1.4 |
| 18 | 18 | 18 | 18 | 18 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | 0 to 70 |
| PDIP SO SOIC TSSOP | PDIP SO SOIC | PDIP SO SOIC TSSOP | PDIP SO SOIC | PDIP SOIC |
| See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) |
| Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps |
| 200 | 200 | 200 | 200 | 200 |
| 100 | 100 | 100 | 100 | 100 |
| 10 | 10 | 10 | 10 | 10 |
| FET | FET | FET | FET | FET |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
