数据:
LMx24, LMx24x, LMx24xx, LM2902, LM2902x, LM2902xx, LM2902xxx Quadruple Operational Amplifiers 数据表
这些器件由四个独立的高增益频率补偿运算放大器组成,专门设计用于在单一电源或分离电源下工作。电压。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| LM224K | LM224 | LM224A | LM224KA | LM2902 | LM2902-EP | LM2902-Q1 | LM2902K | LM324 | LM324A | LM324K | LM324KA |
| 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| 32 | 32 | 32 | 32 | 26 | 26 | 26 | 26 | 32 | 32 | 32 | 32 |
| 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
| 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- | In to V- |
| 5 | 5 | 2 | 2 | 7 | 7 | 2 | 7 | 7 | 3 | 7 | 3 |
| 0.35 | 0.350 | 0.35 | 0.35 | 0.175 | 0.175 | 0.175 | 0.175 | 0.175 | 0.175 | 0.175 | 0.175 |
| 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 |
| Catalog | Catalog | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | Catalog | Catalog | Catalog | Catalog |
| -25 to 85 | -25 to 85 | -25 to 85 | -25 to 85 | -40 to 125 | -40 to 125 -55 to 125 | -40 to 125 | -40 to 125 | 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 |
| PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC | PDIP SO SOIC TSSOP | TSSOP | SOIC TSSOP | PDIP SO SOIC SSOP TSSOP | PDIP SO SOIC TSSOP | PDIP SO SOIC SSOP TSSOP | PDIP SO SOIC TSSOP | PDIP SO SOIC TSSOP |
| See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14SSOP: 48 mm2: 7.8 x 6.2(SSOP) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14SSOP: 48 mm2: 7.8 x 6.2(SSOP) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | |||
| N/A | N/A | N/A | N/A | Standard Amps | N/A | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps |
| 250000 | 250000 | 80000 | 80000 | 250000 | 250000 | 250000 | 250000 | 250000 | 100000 | 250000 | 100000 |
| 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
| 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
| Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
