数据:
Quadruple Operational Amplifiers 数据表
LM148,LM248和LM348是四路独立的高增益内部补偿运算放大器,其工作特性与μA741类似。这些放大器的电源电流消耗和输入偏置电压较低,偏置电流远低于μA741。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| LM348 | LM148 | LM248 | LM2902 | LM324 |
| 4 | 4 | 4 | 4 | 4 |
| 8 | 8 | 8 | 3 | 3 |
| 36 | 36 | 36 | 26 | 32 |
| 1 | 1 | 1 | 1.2 | 1.2 |
| 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| No | No | In to V- | In to V- | |
| 6 | 5 | 6 | 7 | 7 |
| 0.6 | 0.6 | 0.6 | 0.175 | 0.175 |
| 60 | 60 | 60 | 35 | 35 |
| Catalog | Military | Catalog | Catalog | Catalog |
| 0 to 70 | -55 to 125 | -25 to 85 | -40 to 125 | 0 to 70 |
| PDIP SO SOIC | CDIP LCCC | PDIP SOIC | PDIP SO SOIC TSSOP | PDIP SO SOIC TSSOP |
| See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (CDIP) 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 15 | 15 | 15 | ||
| N/A | N/A | N/A | Standard Amps | Standard Amps |
| 200000 | 200000 | 250000 | 250000 | |
| 90 | 90 | 90 | 80 | 80 |
| 25 | 25 | 25 | 40 | 40 |
| Bipolar | Bipolar | Bipolar | Bipolar | Bipolar |
| 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
