数据:
LT1013x Dual Precision Operational
Amplifier 数据表
LT1013x器件是双精度运算放大器,具有高增益,低电源电流,低噪声和低失调电压温度系数。
LT1013x器件可以采用5 V单电源供电;共模输入电压范围包括接地,输出也可以摆动到几毫伏的接地范围内。消除了交叉失真。 LT1013x可以采用双±15 V和单5V电源供电。
LT1013C和LT1013D的工作温度范围为0°C至70°C。 LT1013DI的工作温度范围为-40°C至105°C。 LT1013M,LT1013AM和LT1013DM的工作温度范围为55°C至125°C。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Offset Drift (Typ) (uV/C) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| CMRR (Typ) (dB) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Input Bias Current (Max) (pA) |
| Output Current (Typ) (mA) |
| Features |
| Architecture |
| LT1013D | LT1013 | LT1014 | LT1014D |
| 2 | 2 | 4 | 4 |
| 4 | 4 | 5 | 5 |
| 44 | 44 | 44 | 44 |
| 0.7 | 0.7 | 0.7 | 0.7 |
| 0.4 | 0.4 | 0.4 | 0.4 |
| In to V- | In to V- | In to V- | In to V- |
| 0.8 | 0.3 | 0.3 | 0.8 |
| 0.5 | 0.4 | 0.4 | 0.5 |
| 0.35 | 0.35 | 0.35 | 0.35 |
| 22 | 22 | 22 | 22 |
| 114 | 114 | 117 | 117 |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 105 -55 to 125 0 to 70 | 0 to 70 | 0 to 70 | -40 to 105 -55 to 125 0 to 70 |
| PDIP SOIC | PDIP SOIC | PDIP | PDIP SOIC |
| See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) | See datasheet (PDIP) 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) |
| 30000 | 30000 | 30000 | |
| 25 | 25 | 25 | 25 |
| N/A | N/A | N/A | N/A |
| Bipolar | Bipolar | Bipolar | Bipolar |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
