数据:
LM6171 High Speed Low Power Low Distortion Voltage Feedback Amplifier 数据表
LM6171是一款高速单位增益稳定电压反馈放大器。它提供3600V /μs的高压摆率和100 MHz的单位增益带宽,同时仅消耗2.5 mA的电源电流。 LM6171具有令人印象深刻的交流和直流性能,这对高速信号处理和视频应用非常有利。
±15V电源可实现大信号摆幅,并提供更大的动态范围和信号 - 噪音比。 LM6171具有高输出电流驱动,低SFDR和THD,是ADC /DAC系统的理想选择。 LM6171适用于便携式应用的±5V工作。
LM6171基于TI先进的VIP III(垂直集成PNP)互补双极性工艺制造。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| LM6171 | LM6172 | LM7171 | LMH6654 |
| Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB |
| 1 | 2 | 1 | 1 |
| 5.5 | 5.5 | 5.5 | 4.5 |
| 34 | 36 | 36 | 12 |
| 160 | 160 | 220 | 250 |
| 1 | 1 | 2 | 1 |
| 3600 | 3000 | 4100 | 200 |
| 12 | 12 | 14 | 4.5 |
| 2.5 | 2.3 | 6.5 | 4.5 |
| 3 | 1.5 | 1 | 3 |
| No | No | No | In to V- |
| N/A | N/A | Decompensated | N/A |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| PDIP SOIC | PDIP SOIC | PDIP SOIC | SOIC SOT-23 |
| See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 110 | 110 | 105 | 90 |
| 3000000 | 1500000 | 10000000 | 10000000 |
| 6 | 6 | 35 | 6 |
| 160 | 160 | 440 | 250 |
| 135 | 85 | 100 | 186 |
| 50 | 50 | 75 | 80 |
| 50 | 50 | 55 | 85 |
| 5 | 5 | 5 | 1 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
