数据:
High-Speed Fully Differential I/O Amplifiers 数据表
PowerPAD是德州仪器的商标。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4141 | THS4130 | THS4131 | THS4140 | THS4150 | THS4151 |
| Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 4 | 4 | 4 | 4 | 4 | 4 |
| 33 | 33 | 33 | 33 | 33 | 33 |
| 160 | 150 | 150 | 160 | 150 | 150 |
| 450 | 52 | 52 | 450 | 650 | 650 |
| 6.5 | 1.3 | 1.3 | 6.5 | 7.6 | 7.6 |
| 6.7 | 1.5 | 1.5 | 6.7 | 8 | 8 |
| 13.2 | 12.3 | 12.3 | 13.2 | 17.5 | 17.5 |
| 7 | 2 | 2 | 7 | 7 | 7 |
| No | No | No | No | No | No |
| N/A | Shutdown | N/A | Shutdown | Shutdown | N/A |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC | MSOP-PowerPAD SOIC VSSOP |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 84 | 95 | 95 | 84 | 83 | 83 |
| 15000000 | 6000000 | 6000000 | 15000000 | 15000000 | 15000000 |
| 7 | 4.5 | 4.5 | 7 | 7 | 7 |
| 170 | 170 | 170 | 170 | 150 | 150 |
| 85 | 85 | 85 | 85 | 85 | 85 |
| 83 | 88 | 88 | 83 | 85 | 85 |
| 80 | 84 | 84 | 80 | 88 | 88 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
