数据:
Family of High Output Drive Operational Amplifiers with Shutdown 数据表
TLV411x单电源运算放大器在5 V时提供超过300 mA的输出电流。这使标准引脚输出放大器可用作高电流缓冲器或在线圈驱动器应用中。 TLV4110和TLV4113具有关断功能。
TLV411x采用超小型MSOP PowerPAD?封装,提供提供高电流电平的放大器所需的出色热阻抗。
所有TLV411x器件均采用PDIP,SOIC(单通道和双通道)和MSOP PowerPAD(双通道)提供。
PowerPAD是德州仪器公司的商标。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| Output Current (Typ) (mA) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Offset Drift (Typ) (uV/C) |
| Iq per channel (Typ) (mA) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Rail-to-Rail |
| Architecture |
| TLV4113 | TLV4110 | TLV4111 | TLV4112 |
| 2 | 1 | 1 | 2 |
| 2.5 | 2.5 | 2.5 | 2.5 |
| 6 | 6 | 6 | 6 |
| 320 | 320 | 320 | 320 |
| 2.7 | 2.7 | 2.7 | 2.7 |
| 1.57 | 1.57 | 1.57 | 1.57 |
| 3.5 | 3.5 | 3.5 | 3.5 |
| 3 | 3 | 3 | 3 |
| 0.7 | 0.7 | 0.7 | 0.7 |
| Shutdown | Shutdown | N/A | N/A |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 0 to 70 | -40 to 125 0 to 70 |
| MSOP-PowerPAD PDIP SOIC | MSOP-PowerPAD PDIP SOIC | MSOP-PowerPAD SOIC | MSOP-PowerPAD PDIP SOIC |
| 10MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 25 | 25 | 25 | 25 |
| 68 | 68 | 68 | 68 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| CMOS | CMOS | CMOS | CMOS |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
