数据:
THS4120, THS4121: High-Speed Fully Differential-I/O Amplifier 数据表
THS412x是使用德州仪器(Texas Instruments)制造的全差分输入差分输出器件系列中的一款产品。最先进的亚微米CMOS工艺。
THS412x包含从输入到输出的真正全差分信号路径。这样可以获得出色的共模噪声抑制和改善的总谐波失真。
Hz输入参考噪声(10 kHz)< small> PowerPAD是德州仪器公司的商标。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4120 | THS4121 | THS4520 |
| CMOS Fully Differential Voltage FB | CMOS Fully Differential Voltage FB | Voltage FB |
| 1 | 1 | 1 |
| 3 | 3 | 3 |
| 3.5 | 3.5 | 5.25 |
| 100 | 100 | 620 |
| 1 | 1 | 1 |
| 55 | 55 | 570 |
| 5.4 | 5.4 | 2 |
| 16 | 16 | 2 |
| 11 | 11 | 14.2 |
| 8 | 8 | 2.5 |
| In to V+ Out | In to V+ Out | Out |
| Shutdown | N/A | Shutdown |
| Catalog | Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 |
| MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | VQFN |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 16VQFN: 9 mm2: 3 x 3(VQFN) |
| 96 | 96 | 84 |
| 1.2 | 1.2 | 10000000 |
| 25 | 25 | 1 |
| 100 | 100 | 1200 |
| 25 | 25 | 105 |
| 79 | 79 | 115 |
| 93 | 93 | 123 |
| 1 | 1 | 0.1 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
