数据:
350 mA +/-12V ADSL CPE Line Drivers 数据表
THS6042 /3是一款高速线路驱动器,非常适合在非对称数字用户线(ADSL)应用中驱动从远程终端到中心局的信号。它可以在±12 V电源电压下工作,同时每通道仅吸收8.2 mA的电源电流。它提供低~79 dBc的总谐波失真,驱动100-
负载(2 Vpp)。 THS6042 /3提供高达43 Vpp的差分输出摆幅,从±12开始,载荷为±12。{imf src =“http://focus.ti.com/graphics/shared/symbols/uc/Omega.gif”> -V供应。 THS6043具有低功耗关断模式,每通道仅消耗300 uA静态电流。 THS6042 /3采用标准SOIC,SOIC PowerPAD和TSSOP PowerPAD封装。
,±12-V Supply
加载)PowerPAD是德州仪器的商标。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS6043 | THS6042 | THS6053 |
| Current FB | Current FB | Current FB |
| 2 | 2 | 2 |
| 9 | 9 | 9 |
| 33 | 33 | 33 |
| 120 | 120 | 170 |
| 1 | 1 | 1 |
| 1400 | 1400 | 1700 |
| 2.2 | 2.2 | 2.1 |
| 2.4 | 2.4 | |
| 8.2 | 8.2 | 5.2 |
| 16 | 16 | 10 |
| No | No | No |
| Shutdown | N/A | Shutdown |
| Catalog | Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| HTSSOP SOIC | SO PowerPAD SOIC | HTSSOP |
| 14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8SO PowerPAD: 19 mm2: 3.9 x 4.89(SO PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) |
| 68 | 68 | 66 |
| 10000000 | 10000000 | 10000000 |
| 20 | 20 | 30 |
| 120 | 120 | 170 |
| 350 | 350 | 175 |
| 67 | 67 | |
| 96 | 96 | |
| 1 | 1 | |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
