THS4501 高速全差动放大器,+/-5V
KANA 发表于 2018-11-02 18:16:06
数据: Wideband, Low-Distortion, Fully Differential Amplifiers. 数据表
THS4500和THS4501是德州仪器(TI)的高性能全差分放大器。具有省电功能的THS4500和无断电功能的THS4501为全差分放大器设定了新的性能标准,具有无与伦比的线性度,支持40 MHz的14位操作。封装选项包括SOIC-8和带PowerPAD的MSOP-8,占用空间更小,交流性能更强,散热能力更强。
特性
  • 全差分架构
  • 带宽:370 MHz
  • 压摆率:2800 V /μs< /li>
  • IMD 3 :30 MHz时-90 dBc
  • OIP 3 :30 MHz时49 dBm
  • 输出共模控制
  • 宽电源电压范围:5 V,±5 V,12 V,15 V
  • 输入共模范围转换为包含负电源 - 供应轨道
  • 断电能力(THS4500)
  • 评估模块可用
参数 与其它产品相比 高速 运算放大器 (GBW>=50MHz)
Architecture
Number of Channels (#)
Total Supply Voltage (Min) (+5V=5, +/-5V=10)
Total Supply Voltage (Max) (+5V=5, +/-5V=10)
BW @ Acl (MHz)
Acl, min spec gain (V/V)
Slew Rate (Typ) (V/us)
Vn at Flatband (Typ) (nV/rtHz)
Vn at 1kHz (Typ) (nV/rtHz)
Iq per channel (Typ) (mA)
Vos (Offset Voltage @ 25C) (Max) (mV)
Rail-to-Rail
Features
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
CMRR (Typ) (dB)
Input Bias Current (Max) (pA)
Offset Drift (Typ) (uV/C)
GBW (Typ) (MHz)
Output Current (Typ) (mA)
2nd Harmonic (dBc)
3rd Harmonic (dBc)
@ MHz
THS4501 THS4500 THS4502 THS4503 THS4504 THS4505
Fully Differential     Fully Differential     Fully Differential     Fully Differential     Fully Differential     Fully Differential
1     1     1     1     1     1
4.5     4.5     4.5     4.5     4.5     4.5
15     15     15     15     15     15
370     370     370     370     260     260
1     1     1     1     1     1
2800     2800     2800     2800     1800     1800
7     7     6.8     6.8     8     8
27     27     27     27     21     21
23     23     23     23     16     16
7     7     4     4     7     7
In to V-     In to V-     No     No     In to V-     In to V-
N/A     Shutdown     Shutdown     N/A     Shutdown     N/A
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
0 to 70
-40 to 85
-40 to 85     -40 to 85
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
80     80     80     80     80     80
4600000     4600000     4600000     4600000     4600000     4600000
10     10     10     10     10     10
300     300     300     300     210     210
120     120     120     120     130     130
82     82     83     83     79     79
97     97     97     97     93     93
8     8     8     8     8     8
方框图 (1)
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
