数据:
Low-Distortion High-Speed Rail-to-Rail Output Operational Amplifiers 数据表
THS4222系列是一组轨到轨输出单,双和三低电压,高输出摆幅,低失真高高速放大器非常适合驱动数据转换器,视频切换或低失真应用。该系列电压反馈放大器可在单个15 V电源下工作,直至单个3 V电源,每个通道仅消耗14 mA的静态电流。此外,该系列还具有出色的交流性能,带宽为230 MHz,压摆率为975 V /μs,谐波失真(THD)在5 MHz时为90 dBc。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4222 | THS4221 |
| Bipolar Voltage FB | Bipolar Voltage FB |
| 2 | 1 |
| 2.7 | 2.7 |
| 15 | 15 |
| 230 | 230 |
| 1 | 1 |
| 990 | 990 |
| 13 | 13 |
| 13 | 13 |
| 14 | 14 |
| 10 | 10 |
| No | No |
| N/A | N/A |
| Catalog | Catalog |
| -40 to 85 | -40 to 85 |
| MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC SOT-23 VSSOP |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 94 | 94 |
| 3000000 | 3000000 |
| 20 | 20 |
| 230 | 230 |
| 100 | 100 |
| 92 | 92 |
| 96 | 96 |
| 1 | 1 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
