数据:
LPV811/LPV812 425nA 精密毫微功耗运算放大器 数据表 (Rev. B)
LPV811(单通道)和LPV812(双通道)系列超低功耗精密运算放大器是由电池供电的无线设备和低功耗有线设备中文翻译手机版气体检测器和便携式电子设备)将功耗降至最低。
除超低功耗特性外,LPV81x放大器还具有实现毫微微偏置电流的CMOS输入级,可用于阻抗源应用.LPV81x放大器还特有一个负轨感测输入级和一个相对于电源轨的摆幅为毫伏级的轨到轨输出级,从而尽可能保持最宽的动态范围.LPV81x设有电磁干扰(EMI )保护,可降低来自手机,WiFi,无线电发射器和标签阅读器的无用射频信号对系统造成的影响。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| Iq per channel (Max) (mA) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Features |
| Package Size: mm2:W x L (PKG) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Output Current (Typ) (mA) |
| Architecture |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| LPV811 | LPV801 | LPV802 | LPV821 | OPA2369 | OPA369 | TLV8802 | TLV8811 | TLV8812 |
| 1 | 1 | 2 | 1 | 2 | 1 | 2 | 1 | 2 |
| 1.6 | 1.6 | 1.6 | 1.7 | 1.8 | 1.8 | 1.7 | 1.7 | 1.7 |
| 5.5 | 5.5 | 5.5 | 3.6 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 0.00054 | 0.00054 | 0.000415 | 0.00079 | 0.001 | 0.0012 | 0.00065 | 0.00075 | 0.0007 |
| 0.00045 | 0.00045 | 0.00032 | 0.00065 | 0.0007 | 0.0008 | 0.00032 | 0.00045 | 0.000425 |
| 0.37 | 3.5 | 3.5 | 0.01 | 0.75 | 0.75 | 4.5 | 0.55 | 0.5 |
| 1 | 1.5 | 1.5 | 0.02 | 0.4 | 0.4 | 1 | 1 | 1 |
| 0.008 | 0.008 | 0.008 | 0.008 | 0.012 | 0.012 | 0.006 | 0.006 | 0.006 |
| 0.0017 | 0.0018 | 0.0018 | 0.0033 | 0.005 | 0.005 | 0.0015 | 0.0015 | 0.0015 |
| In to V- Out | In to V- Out | In to V- Out | In Out | In Out | In Out | In to V- Out | In to V- Out | In to V- Out |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 |
| SOT-23 | SOT-23 | VSSOP | SOT-23 | SOT-23 VSSOP | SC70 | VSSOP | SOT-23 | VSSOP |
| EMI Hardened | EMI Hardened | EMI Hardened | Zero Drift EMI Hardened | EMI Hardened Zero Crossover | EMI Hardened Zero Crossover | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened |
| 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SC70: 4 mm2: 2.1 x 2(SC70) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 420 | 420 | 420 | 215 | 290 | 290 | 450 | 450 | 450 |
| 4.7 | 4.7 | 4.7 | 21 | 10 | 10 | 4.7 | 4.7 | 4.7 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | |
| 50 | 50 | |||||||
| 95 | 98 | 98 | 125 | 114 | 114 | 90 | 95 | 98 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
