数据:
LM2903-Q1 Automotive Dual Differential Comparators 数据表
该器件由两个独立的电压比较器组成,设计用于在宽电压范围内通过单个电源供电。只要两个电源之间的差值为2 V至36 V,并且VCC比输入共模电压至少高1.5 V,就可以使用双电源供电。电流消耗与电源电压无关。输出可以连接到其他开集输出,以实现有线和关系。
LM2903-Q1符合AEC-Q100 1级温度范围-40的要求°C至+ 125°C。 LM2903E-Q1符合AEC-Q100 0级温度范围-40°C至+ 150°C™
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Output Type |
| Vs (Min) (V) |
| Vs (Max) (V) |
| Propagation Delay Time (uS) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Input Bias Current (+/-) (Max) (nA) |
| Rail-to-Rail |
| Rating |
| Operating Temperature Range (C) |
| Features |
| VICR (Max) (V) |
| VICR (Min) (V) |
| Package Group |
| LM2903-Q1 | LM193 | LM2903 | LM2903V | LM293 | LM293A | LM393 | LM393A | TLV1701-Q1 | TLV1702-Q1 | TLV1704-Q1 |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 1 | 2 | 4 |
| Open Collector | Open Collector Open Drain | Open Collector | Open Collector | Open Collector | Open Collector | Open Collector | Open Collector | Open Collector | Open Collector | Open Collector |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 4 | 2.2 | 2.2 | 2.2 |
| 30 | 36 | 30 | 32 | 36 | 36 | 36 | 30 | 36 | 36 | 36 |
| 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 0.3 | 0.3 | 0.46 | 0.56 | 0.56 |
| 7 | 5 | 7 | 7 | 5 | 2 | 5 | 2 | 3.2 | 2.5 | 2.5 |
| 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.2 | 0.2 | 0.055 | 0.055 | 0.055 |
| 50 | 25 | 50 | 50 | 50 | 50 | 50 | 50 | 15 | 15 | 15 |
| Out | Out | Out | Out | Out | Out | Out | Out | In | In | In |
| Automotive | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Automotive | Automotive | Automotive |
| -40 to 125 -40 to 150 | -55 to 125 | -40 to 125 | -40 to 125 | -25 to 85 | -25 to 85 | 0 to 70 | 0 to 70 | -40 to 125 | -40 to 125 | -40 to 125 |
| N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| 30.5 | 34.5 | 28.5 | 30.5 | 34.5 | 34.5 | 34.5 | 34.5 | 36 | 36 | 36 |
| 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 2.2 | 2.2 | 2.2 |
| SOIC TSSOP VSSOP | SOIC | PDIP SO SOIC TSSOP VSSOP | SOIC TSSOP | PDIP SOIC VSSOP | SOIC VSSOP | PDIP SO SOIC TSSOP VSSOP | PDIP SO SOIC TSSOP VSSOP | SOT-23 | VSSOP | TSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
