数据:
TLV170x-Q1 2.2-V to 36-V, microPower
Comparator 数据表
TLV1701-Q1(单通道),TLV1702-Q1(双通道)和TLV1704-Q1(四通道)器件提供宽电源范围,轨到轨输入,低静态电流和低传播延迟。所有这些功能都采用行业标准,极小的封装,使这些器件成为最好的通用比较器。
集电极开路输出提供的优势是可以将输出拉至最高达36的任何电压轨。无论TLV170x-Q1电源电压如何,V都高于负电源。
该器件是microPower比较器。低输入失调电压,低输入偏置电流,低电源电流和集电极开路配置使TLV170x-Q1器件具有足够的灵活性,可以处理几乎任何应用,从简单的电压检测到驱动单个继电器。
该器件的额定工作温度范围为-40°C至+ 125°C扩展工业温度范围。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Output Type |
| Vs (Min) (V) |
| Vs (Max) (V) |
| Propagation Delay Time (uS) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Input Bias Current (+/-) (Max) (nA) |
| Rail-to-Rail |
| Rating |
| Operating Temperature Range (C) |
| Features |
| VICR (Max) (V) |
| VICR (Min) (V) |
| Package Group |
| TLV1704-Q1 | LM2903-Q1 | TLV1701-Q1 | TLV1702-Q1 |
| 4 | 2 | 1 | 2 |
| Open Collector | Open Collector | Open Collector | Open Collector |
| 2.2 | 2 | 2.2 | 2.2 |
| 36 | 30 | 36 | 36 |
| 0.56 | 1.3 | 0.46 | 0.56 |
| 2.5 | 7 | 3.2 | 2.5 |
| 0.055 | 0.4 | 0.055 | 0.055 |
| 15 | 50 | 15 | 15 |
| In | Out | In | In |
| Automotive | Automotive | Automotive | Automotive |
| -40 to 125 | -40 to 125 -40 to 150 | -40 to 125 | -40 to 125 |
| N/A | N/A | N/A | N/A |
| 36 | 30.5 | 36 | 36 |
| 2.2 | 0 | 2.2 | 2.2 |
| TSSOP | SOIC TSSOP VSSOP | SOT-23 | VSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
