数据:
High-Side, Bidirectional Current Shunt Monitor 数据表
INA170是一款高端双向电流分流监控器,具有宽输入共模电压范围,低静态电流和微小的MSOP-8封装。
双向电流测量由输出偏移完成。通过外部电阻和参考电压设置偏移电压电平。这允许在使用INA170的单电源时测量双向分流电流。
输入共模和电源电压是独立的。在+ 2.7V至+ 40V的任何电源电压下,输入电压范围为+ 2.7V至+ 60V。低10μA输入偏置电流可为分流电流增加最小误差。
INA170将差分输入电压转换为电流输出。该电流在外部负载电阻上产生电压,将增益从1设置为100以上。
INA170采用MSOP-8封装,工作在扩展工业温度范围内。工作温度范围为40°C至+ 85°C,工作温度范围为?55°C至+ 125°C。
所有商标均为各自所有者的财产。
| Common Mode Voltage (Max) (V) |
| Common Mode Voltage (Min) (V) |
| Input Offset (+/-) (Max) (uV) |
| Input Offset Drift (+/-) (Typ) (uV/C) |
| Gain (V/V) |
| Gain Error (%) |
| Gain Error Drift (Max) (ppm/°C) |
| CMRR (Min) (dB) |
| Bandwidth (kHz) |
| Supply Voltage (Max) (V) |
| Supply Voltage (Min) (V) |
| Iq (Max) (mA) |
| Number of Channels (#) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| INA170 | INA138 | INA139 | INA168 | INA169 |
| 60 | 36 | 36 | 60 | 60 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 1000 | 1000 | 1000 | 1000 | 1000 |
| 1 | 1 | 1 | 1 | 1 |
| Adjustable | Adjustable | Adjustable | Adjustable | Adjustable |
| 2 | 2 | 2 | 2 | 2 |
| 100 | 100 | 100 | 100 | 100 |
| 4000 | 800 | 4400 | 800 | 4400 |
| 60 | 36 | 40 | 60 | 60 |
| 0.125 | 0.06 | 0.125 | 0.06 | 0.125 |
| 1 | 1 | 1 | 1 | 1 |
| Bi-directional Current Output | Current Output | Current Output | Current Output | Current Output |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| VSSOP | SOT-23 | SOT-23 | SOT-23 | SOT-23 |
| 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
