TPA2006D1器件是一款1.45 W高效无滤波D类音频功率放大器,采用3 mm×3 mm VSON封装,仅需三个外部组件。 SHUTDOWN 引脚与1.8 V逻辑GPIO完全兼容,例如用于低功耗蜂窝芯片组。
88等功能TPA2006D1器件具有%效率,75-dB PSRR,改善的RF整流抗扰度和较小的PCB总占位面积,是蜂窝手机的理想选择。 TPA2006D1设备具有1 ms的快速启动时间和最小的弹出功能,是PDA应用的理想选择。
在手机中,耳机,扬声器电话和旋律振铃器均可由TPA2006D1设备驱动。 TPA2006D1器件允许独立增益,同时对来自不同源的信号求和,并具有低36-μV本底噪声,A加权。
TPA2006D1器件具有短路和热保护功能。
< /DIV>
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TPA2006D1 | TPA2005D1 |
| Analog Input | Analog Input |
| Class-D | Class-D |
| Mono | Mono |
| 2.5 | 2.5 |
| 5.5 | 5.5 |
| 1.45 | 1.4 |
| 8 | 8 |
| 97 | 97 |
| 0.19 | 0.2 |
| 3.4 | 2.8 |
| Hardware | Hardware |
| Open | Closed |
| 2.5 | 2.5 |
| 5.5 | 5.5 |
| 75 | 75 |
| -40 to 85 | -40 to 85 |
| Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
