数据:
TPA2005D1-Q1 1.4-W Mono Filter-Free Class-D
Audio Power Amplifier 数据表
TPA2005D1-Q1器件是一款1.4 W高效无滤波器D类音频功率放大器,采用SON或MSOP-PowerPAD封装,要求仅有三个外部元件。
效率高达84%,217 Hz时-71 dB PSRR,改善射频整流抗扰度和15 mm 2 总PCB面积等特性使TPA2005D1成为可能-Q1适用于信息娱乐和集群中的低功耗音频应用。
该器件通过对来自每个功能的信号求和,同时将噪声降至仅48μV RMS ,允许独立的增益控制。此外,TPA2005D1-Q1器件具有9 ms的快速启动时间和最小的弹出功能,并具有短路和热保护功能。
对于所有可用的软件包,请参阅数据表末尾的可订购附录。
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TPA2005D1-Q1 | LM48100Q-Q1 | TAS2505-Q1 | TAS2521 |
| Analog Input | Analog Input | Analog Input Digital Input | Analog Input Digital Input |
| Class-D | Class-AB | Class-D | Class-D |
| Mono | Mono | Mono | Mono |
| 4.4 | 3 | 2.7 | 1.5 |
| 5.5 | 5.5 | 5.5 | 1.95 |
| 1.18 | 2.4 | 2.6 | 2 |
| 8 | 8 | 4 | 4 |
| 97 | 104 | 94 | 94 |
| 0.2 | 0.04 | 0.02 | 0.012 |
| 2.8 | 4.4 | 0.002 | 0.002 |
| Hardware | I2C | I2C SPI | I2C SPI |
| Open | Closed | Closed | Open |
| 4.5 | 3 | 1.5 | 1.5 |
| 5.5 | 5.5 | 1.95 | 1.95 |
| 75 | 74 | 47.2 | 47.2 |
| -40 to 105 -40 to 85 | -40 to 105 | -40 to 105 | -40 to 85 |
| Automotive | Automotive | Automotive | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
