数据:
TAS5760L 通用 I2S 输入 D 类放大器 数据表 (Rev. C)
TAS5760L是一款立体声I2S输入器件,具有硬件和软件(I²C)控制模式,集成数字削波器,多种增益选项并且电源运行电压范围较大,支持其适用于多种应用非常有用.TAS5760L运行电压范围为4.5V至15VDC的标称电源电压。
输出金属氧化物半导体场效应应晶体管(MOSFET)的120mΩ DS(ON)兼顾散热性能与器件成本,二者相得益彰。此外,该器件采用耐热增强型48-Pin TSSOP封装,在现代消费类电子器件的较高工作环境温度下展现出优异的性能。
整个TAS5760xx系列均采用48针TSSOP封装,并且所有系列成员器件之间彼此引脚到引脚兼容。另外,对于可能不需要耳机/线路驱动器不要求引脚至引脚兼容,但希望解决方案实现最小化的应用,TAS5760M和TAS5760L器件可采用32引脚薄型小外形尺寸(TSSOP)封装.TAS5760xx系列所有器件的I 2 C寄存器映射是相同的,这样一来,当需要根据系统级要求更换器件时,可以减少二次开发的工作量。
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| Power to Parallel Bridge Tied Load (Max) (W) |
| Sampling Rate (Max) (kHz) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TAS5760L | TAS5704 | TAS5706B | TAS5716 | TAS5720L | TAS5720M | TAS5760M |
| Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input |
| Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D |
| Stereo | 4 | 4 | 4 | Mono | Mono | Stereo |
| 4.5 | 10 | 10 | 10 | 4.5 | 4.5 | 4.5 |
| 16.5 | 26 | 26 | 26 | 16.5 | 26.4 | 26.4 |
| 21 | 20 | 20 | 20 | 39 | 39 | 55 |
| 2 | 4 | 4 | 4 | 4 | 4 | 2 |
| 100 | 100 | 99 | 99 | 100 | ||
| 0.09 | 0.05 | 0.05 | 0.05 | 0.015 | 0.015 | 0.03 |
| 33 | 33 | 33 | 10.3 | 10.3 | ||
| Hardware Software | Hardware | Hardware Software | Hardware Software | Software | Software | Hardware Software |
| Closed | Closed | Closed | Open | Closed | Closed | Closed |
| 4.5 | 3 | 3 | 3 | 4.5 | 4.5 | 4.5 |
| 16.5 | 3.6 | 3.6 | 3.6 | 16.5 | 26.4 | 26.4 |
| 43.2 | 60 | 43.2 | ||||
| 192 | 192 | 192 | 192 | 96 | 96 | 96 |
| 60 | 60 | 60 | 87 | |||
| -25 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | -25 to 85 | -25 to 85 | -25 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
