数据:
TPA3244 60W 立体声、110W 峰值 PurePath™ 超高清 D
类放大器(焊盘朝下) 数据表 (Rev. A)
TPA3244器件是一款高性能D类功率放大器,具有D类效率并且能够提供真正的高端音质。该器件特有高级集成反馈设计和专有高速栅极驱动器错误校正功能(的PurePath超清)。该技术可使器件在整个音频频带内保持超低失真,同时展现完美音质。该器件采用30V电源,最多可驱动2个110W(峰值功率)/4Ω负载和2个60W(连续功率)/8Ω负载,并且具有一个2 VRMS模拟输入接口,支持与TI的Burr-Brown PCM52xx DAC系列这类高性能DAC(例如PCM5242 /PCM5252)无缝连接。除了出色的音频性能外,TPA3244还兼具高功率效率和超低功率级空闲损耗(0.45W以下)两大优点。这可以利用65mΩMOSFET以及优化型栅极驱动器方案来实现,该方案相比传统的分立实现方案可显着降低空闲损耗。
< /DIV>
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| Power to Parallel Bridge Tied Load (Max) (W) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TPA3244 | TPA3220 | TPA3221 | TPA3245 | TPA3250 | TPA3251 | TPA3255 |
| Analog Input | Analog Input | Analog Input | Analog Input | Analog Input | Analog Input | Analog Input |
| Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D |
| 4 | Stereo | Stereo | 4 | 4 | 4 | 4 |
| 12 | 7 | 7 | 12 | 12 | 12 | 18 |
| 30 | 30 | 30 | 30 | 36 | 36 | 53.5 |
| 100 | 100 | 100 | 115 | 130 | 175 | 315 |
| 1.5 | 1 | 1 | 1.5 | 1.5 | 1.5 | 4 |
| 110 | 108 | 108 | 112 | 110 | 111 | 112 |
| 0.005 | 0.02 | 0.02 | 0.005 | 0.005 | 0.005 | 0.006 |
| 15 | 15 | 15 | 12.5 | 12.5 | 24 | |
| Hardware | Hardware | Hardware | Hardware | Hardware | Hardware | Hardware |
| Closed | Closed | Closed | Closed | Closed | Closed | Closed |
| 10.8 | 5 | 5 | 10.8 | 10.8 | 10.8 | 10.8 |
| 13.2 | 30 | 30 | 13.2 | 13.2 | 13.2 | 13.2 |
| 160 | 200 | 200 | 230 | 189 | 355 | 600 |
| 60 | 60 | 60 | 60 | 60 | 80 | 80 |
| 0 to 70 | -40 to 85 | -40 to 85 | 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
