数据:
TAS2555具有 H 类升压和扬声器感应功能的 5.7W D 类单声道音频放大器 数据表 (Rev. A)
TAS2555器件是一款先进的D类音频放大器,也是一套功能完备的片上系统(SoC)。该器件具有超低噪声音频DAC以及具备扬声器电压和电流感测反馈的D类功率放大器。片上低延迟DSP支持德州仪器(TI)的SmartAmp扬声器保护算法,能够在维持扬声器处于安全状态的同时,最大限度提高扬声器的音量。
该器件可通过I2S输出轻松与任何处理器搭配使用,而且使用两个TAS2555器件时能够实现立体声。该器件可针对不同的扬声器单独进行调试,这使得客户能够在保持原有外形此外,无论在哪种工作模式下,TAS2555均能以15.9μV超低ICN对语音和音频单独进行动态调试,从而使得接收器/扬声器的实现成为可能p>
H类升压转换器生成D类放大器电源轨。如果音频信号仅需要较低的D类输出功率,则升压转换器会通过禁用V BAT 并将其直接连接至D类放大器电源来提高系统效率。当需要较高的音频输出功率时,多级升压功能会迅速激活信号跟踪,从而为负载提供额外的电压。
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TAS2555 | TAS2552 | TAS2553 | TAS2557 | TAS2559 | TAS2560 |
| Digital Input | Analog Input Digital Input | Analog Input Digital Input | Digital Input | Digital Input | Digital Input |
| Class-D Boosted Smart Amp | Class-D Boosted Smart Amp | Class-D Boosted | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp |
| Mono | Mono | Mono | Mono | Mono | Mono |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 5.7 | 4 | 2.8 | 5.7 | 5.7 | 5.6 |
| 4 | 6 | 6 | 4 | 4 | 4 |
| 111 | 94 | 94 | 111 | 111 | 111 |
| 0.02 | 0.1 | 0.9 | 0.0035 | 0.0035 | 0.004 |
| 3 | 6.54 | 7.1 | 3.9 | 3.9 | 3.2 |
| I2C SPI | I2C | I2C | I2C SPI | I2C SPI | I2C |
| Closed | Closed | Closed | Closed | Closed | Closed |
| 2.95 | 2.7 | 2.7 | 2.9 | 2.9 | 2.9 |
| 110 | 75 | 75 | 110 | 110 | 110 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
