数据:
TAS2553 2.8W D 类单声道音频放大器,支持 G 类升压和扬声器感测 数据表 (Rev. B)
TAS2553是一款高效D类音频功率放大器,此放大器具有高级电池电流管理功能和集成G类升压转换器。此器件持续测量负载上的电流和电压,并且提供此类信息的数字流。
G类升压转换器生成D类放大器电源轨。低D类输出功率期间,此升压转换器通过使VBAT无效并将其直接接至D类放大器电源来提升效率。当需要高功率音频时,升压转换器快速激活,以提供比直接接至电池的单独放大器高很多的音频。
< p> AGC自动调节D类增益,以减少充电结束电压上的电池电流,从而防止输出削波,失真和早期系统关断。通过I 2 C调节固定增益。增益范围介在-7dB至+ 24dB之间(步长1dB)。除了差分单声道模拟输入,TAS2553具有使用数字输入的内置16位数模(D /A)转换器。将D /A转换器从数字主机处理器移至集成放器的工艺能够以更低的系统成本提供更佳的动态性能。此外,由于印刷电路板(PCB)传输的是数字信号而非模拟信号,所以系统级上对于外部干扰(例如GSM帧速率噪声)的敏感度被减少。
所有商标均为他们各自的所有者。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TAS2553 | TAS2552 | TAS2555 | TAS2557 | TAS2559 | TAS2560 |
| Analog Input Digital Input | Analog Input Digital Input | Digital Input | Digital Input | Digital Input | Digital Input |
| Class-D Boosted | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp | Class-D Boosted Smart Amp |
| Mono | Mono | Mono | Mono | Mono | Mono |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 2.8 | 4 | 5.7 | 5.7 | 5.7 | 5.6 |
| 6 | 6 | 4 | 4 | 4 | 4 |
| 94 | 94 | 111 | 111 | 111 | 111 |
| 0.9 | 0.1 | 0.02 | 0.0035 | 0.0035 | 0.004 |
| 7.1 | 6.54 | 3 | 3.9 | 3.9 | 3.2 |
| I2C | I2C | I2C SPI | I2C SPI | I2C SPI | I2C |
| Closed | Closed | Closed | Closed | Closed | Closed |
| 2.7 | 2.7 | 2.95 | 2.9 | 2.9 | 2.9 |
| 75 | 75 | 110 | 110 | 110 | 110 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
