数据:
TAS5634 300W 立体声/600W 单声道高清数字输入、58V D 类放大器功率级 数据表
TAS5634是一款PWM输入D类放大器功率级,可在58V标称电源电压下提供2 x 300W(6Ω)或1 x 600W( 3 *)的输出功率.58V电源电压支持较高阻抗的扬声器负载,其中BTL为6Ω,PBTL为3Ω。集成式MOSFET和全新栅极驱动方案具有较高的峰值效率和较低的空闲损耗,能够减小散热器解决方案尺寸。
TAS5634使用闭环反馈设计,具有恒定的电压增益。开关模式电源(SMPS)的使用,使得内部匹配的增益电阻器可确保实现较高的电源抑制比较(PSRR)和较低的输出噪声。
TAS5634是一款兼容TI的数字输入(I2S)音频处理器和调制器产品组合的全集成式功率级,与TAS5548和TAS5558类似,也是一个完整的数字输入D类放大器.TAS5634采用表面安装44引脚HTSSOP封装,是PWM输入D类功率级兼容引脚产品系列(包括TAS5612LA,TAS5614LA和TAS5624A)中的一员
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| Power to Parallel Bridge Tied Load (Max) (W) |
| Sampling Rate (Max) (kHz) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TAS5634 | TAS5612LA | TAS5614LA | TAS5622A | TAS5624A | TAS5631B |
| PWM | PWM | PWM | PWM | PWM | PWM |
| Class-D | Class-D | Class-D | Class-D | Class-D | Class-D |
| 4 | 4 | 4 | 4 | 4 | 4 |
| 12 | 12 | 12 | 12 | 12 | 25 |
| 58 | 32.5 | 36 | 34 | 36 | 52.5 |
| 300 | 125 | 150 | 125 | 150 | 300 |
| 3 | 4 | 4 | 1.5 | 1.5 | 4 |
| 105 | 105 | 105 | 105 | 105 | 103 |
| 0.025 | 0.05 | 0.03 | 0.025 | 0.025 | 0.03 |
| 29.5 | 22.3 | 22.3 | 23.4 | 23.4 | 24.8 |
| Hardware | Hardware | Hardware | Hardware | Hardware | Hardware |
| Closed | Closed | Closed | Closed | Closed | Closed |
| 10.8 | 10.8 | 10.8 | 13.2 | 13.2 | 10.8 |
| 13.2 | 13.2 | 13.2 | 10.8 | 10.8 | 13.2 |
| 600 | 250 | 300 | 300 | 400 | 400 |
| 48 | 48 | 48 | 48 | 48 | 48 |
| 70 | 80 | 80 | 65 | 65 | 80 |
| 0 to 70 | 0 to 125 | 0 to 125 | -40 to 125 | 0 to 70 | 0 to 70 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
