LM2773 Low-Ripple 1.8V/1.6V Spread-Spectrum Switched Capacitor Step-Down Regulator
KANA 发表于 2018-11-02 17:47:05
数据: Low-Ripple 1.8V/1.6V Spread-Spectrum Switched Capacitor Step-Down Regulator 数据表
The LM2773 is a switched capacitor step-down regulator that produces a selectable 1.8V or 1.6V output. It is capable of supplying loads up to 300mA. The LM2773 operates with an input voltage from 2.5V to 5.5V, accommodating 1-cell Li-Ion batteries and chargers.
The LM2773 utilizes a regulated charge pump with gains of 2/3x and 1x. It has very low ripple and noise on both the input and output due to its pre-regulated 1.15MHz (typ.) switching frequency and spread spectrum operation. When output currents are low, the LM2773 automatically switches to a low-ripple PFM regulation mode to maintain high efficiency over the entire load range.
The LM2773 is available in TI's 0.5mm pitch 9-bump DSBGA.
特性
  • 低噪声扩频操作
  • 1.8V /1.6V可选输出电压
  • 2 %输出电压调节
  • > 1.8V模式下效率为75%
  • 极低输出纹波:10mV @ 300mA
  • 输出电流高达300mA
  • 2.5V至5.5V输入电压范围< /li>
  • 关闭断开负载 IN
  • 1.15MHz开关频率
  • 无电感器......小解决方案尺寸
  • 短路和热保护
  • 0.5mm间距,DSBGA-9(1.511×1.511mm×0.6mm)
所有商标均为其各自的商标。拥有者。
参数 与其它产品相比 降压充电泵 (无电感器)
Vin (Min) (V)
Vin (Max) (V)
Vout (Min) (V)
Vout (Max) (V)
Iout (Max) (A)
Regulated Outputs (#)
Switching Frequency (Min) (kHz)
Switching Frequency (Max) (kHz)
Iq (Typ) (mA)
Features
Operating Temperature Range (C)
Package Group
LM2773
2.5
5.5
1.6
1.8
0.3
1
1150
1150
0.048
Enable
-30 to 85
DSBGA
方框图 (3)
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
