数据:
LM26001/-Q1 1.5-A Switching Regulator With High-Efficiency Sleep Mode 数据表
LM26001是一款开关稳压器,专为满足待机模式应用的高效率要求而设计。该器件具有低电流休眠模式,可在轻负载条件下保持效率,并具有电流模式控制,可在宽输入电压范围内实现精确调节。通常在关断模式下静态电流降至10μA,在休眠模式下降至40μA以下。强制PWM模式也可用于禁用睡眠模式。
LM26001可通过内部N通道开关提供高达1.5 A的连续负载电流和固定电流限制。该器件具有4.0 V至38 V的宽输入电压范围,可在线路瞬态期间以低至3 V的输入电压工作。
使用单个电阻器,工作频率可在150 kHz至500 kHz范围内调节,并可与外部时钟同步。
其他功能包括电源良好,可调节软启动,使能引脚,输入欠压保护和内部自举二极管,以减少元件数量。
对于所有可用封装,请参阅可订购的附录。数据表的结尾。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM26001-Q1 | LM26001 | LM26003 | LM26003-Q1 | LM53600-Q1 | LM53601-Q1 | LM53602-Q1 | LM53625-Q1 |
| 3 | 3 | 3 | 3 | 3.5 | 3.5 | 3.5 | 3.5 |
| 38 | 38 | 38 | 38 | 42 | 42 | 42 | 42 |
| 1.25 | 1.25 | 1.25 | 1.25 | 3.3 | 3.2 | 3.2 | 3.2 |
| 35 | 35 | 35 | 35 | 9.9 | 6 | 9.9 | 10 |
| 1.5 | 1.5 | 3 | 3 | 0.65 | 1 | 2 | 2.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 150 | 150 | 150 | 150 | 1890 | 1890 | 1850 | 1850 |
| 500 | 500 | 500 | 500 | 2400 | 2400 | 2350 | 2350 |
| 0.038 | 0.038 | 0.04 | 0.04 | 0.023 | 0.023 | 0.023 | 0.018 |
| Enable Light Load Efficiency Power Good Pre-Bias Start-Up | Enable Power Good | Enable Light Load Efficiency Power Good Pre-Bias Start-Up | Enable Light Load Efficiency Power Good Pre-Bias Start-Up | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Wettable Flanks Package | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Spread Spectrum Synchronous Rectification |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 150 | -40 to 150 | -40 to 150 | -40 to 150 |
| Automotive | Catalog | Catalog | Automotive | Automotive | Automotive | Automotive | Automotive |
| HTSSOP | HTSSOP | HTSSOP | HTSSOP | WSON | WSON | HTSSOP | VQFN-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
