数据:
TPS6211x 17-V, 1.5-A, Synchronous Step-Down Converter 数据表
TPS6211x器件是一系列低噪声同步降压DC-DC转换器,非常适合2至4供电的系统电池锂离子电池或12 V或15 V电压轨。
TPS6211x器件是同步脉冲宽度调制(PWM)转换器,集成了N和P通道功率MOSFET开关。同步整流用于提高效率和减少外部元件数量。为了在宽负载电流范围内实现最高效率,转换器在轻负载电流下进入节能,脉冲频率调制(PFM)模式。工作频率通常为1 MHz,允许使用小电感和电容值。该器件可以与0.8 MHz至1.4 MHz范围内的外部时钟信号同步。对于低噪声操作,转换器可以在仅PWM模式下运行。在关断模式下,电流消耗降至2μA以下。 TPS6211x系列器件采用16引脚(RSA)VQFN封装,工作温度范围为40°C至85°C。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62113 | TPS62110 | TPS62111 | TPS62112 |
| 3.1 | 3.1 | 3.1 | 3.1 |
| 17 | 17 | 17 | 17 |
| 1.2 | 1.2 | 3.3 | 5 |
| 16 | 16 | 3.3 | 5 |
| 1.5 | 1.5 | 1.5 | 1.5 |
| 1 | 1 | 1 | 1 |
| 900 | 900 | 900 | 900 |
| 1100 | 1100 | 1100 | 1100 |
| 0.02 | 0.02 | 0.02 | 0.02 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog |
| QFN | QFN | QFN | QFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
