数据:
Dual-Synchronous, Step-Down Controller With OOA Operation and 100-mA LDOs 数据表
TPS51125A是一款经济高效的双同步降压控制器,适用于笔记本电脑系统电源解决方案。它提供5 V和3.3 V LDO,几乎不需要外部元件。 270 kHz VCLK输出可用于驱动外部电荷泵,为负载开关产生栅极驱动电压,而不会降低主转换器的效率。 TPS51125A支持高效率,快速瞬态响应,并提供组合的电源良好信号。音频外模式轻载操作可实现低噪声,其效率远高于传统的强制PWM操作。自适应导通时间D-CAP控制提供方便和有效的操作。该器件采用5.5 V至28 V的电源输入电压工作,支持2 V至5.5 V的输出电压.TPS51125A采用24引脚QFN封装,额定温度范围为-40°C至85°C环境温度范围。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS51125A | TPS51120 | TPS51123 | TPS51124 | TPS51220 | TPS51220A |
| 5.5 | 4.5 | 5.5 | 3 | 4.5 | 4.5 |
| 28 | 28 | 28 | 28 | 28 | 32 |
| 2 | 1 | 2 | 0.76 | 1 | 1 |
| 5.5 | 5.5 | 5.5 | 5.5 | 12 | 12 |
| 20 | 20 | 20 | 15 | 20 | 20 |
| 2 | 2 | 2 | 2 | 2 | 2 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 300 | 180 | 200 | 240 | 200 | 200 |
| 460 | 500 | 460 | 420 | 1000 | 1000 |
| 0.55 | 0.75 | 0.55 | 0.35 | 1.3 | 1.3 |
| Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification |
| 93 | 88 | 93 | 88 | 99 | 99 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN | VQFN | VQFN | VQFN | VQFN | QFN WQFN |
| D-CAP | Current Mode D-CAP | D-CAP | D-CAP | Current Mode D-CAP | |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
