TPS54240 具有 Eco-Mode 的 3.5V 至 42V 输入、2.5A 降压转换器
KANA 发表于 2018-11-02 17:44:06
数据: TPS54240 3.5-V to 42-V Step-Down DC - DC Converter With Eco-Mode™ 数据表
The TPS54240 device is a 42-V, 2.5-A, step-down regulator with an integrated high-side MOSFET. Current mode control provides simple external compensation and flexible component selection. A low-ripple, pulse skip mode reduces the no load, regulated output supply current to 138 µA. Using the enable pin, shutdown supply current is reduced to 1.3 µA, when the enable pin is low.
Undervoltage lockout is internally set at 2.5 V, but it can be increased using the enable pin. The output voltage startup ramp is controlled by the slow-start pin that can also be configured for sequencing and tracking. An open-drain power good signal indicates the output is within 94% to 107% of its nominal voltage.
A wide switching frequency range allows efficiency and optimization of external component size. Frequency foldback and thermal shutdown protects the part during an overload condition.
The TPS54240 is available in 10-pin, thermally-enhanced HVSSOP and 10-pin 3-mm × 3-mm PowerPAD package.
特性
  • 3.5 V至42 V输入电压范围
  • 200mΩ高边MOSFET
  • < li>具有
    脉冲跳跃Eco-Mode™的轻负载时的高效率
  • 138-μA工作静态电流
  • 1.3-μA关断电流
  • 100 kHz至2.5 MHz开关频率
  • 与外部时钟同步
  • 可调慢启动和排序
  • UV和OV电源良好输出
  • < li>可调UVLO电压和迟滞
  • 0.8V内部参考电压
  • 10针HVSSOP和10针3 mm x 3 mm
    带PowerPAD™的VSON封装
  • WEBENCH ®软件工具支持
参数 与其它产品相比 降压转换器 (集成开关)
Vin (Min) (V)
Vin (Max) (V)
Vout (Min) (V)
Vout (Max) (V)
Iout (Max) (A)
Regulated Outputs (#)
Switching Frequency (Min) (kHz)
Switching Frequency (Max) (kHz)
Iq (Typ) (mA)
Features
Control Mode
Duty Cycle (Max) (%)
Operating Temperature Range (C)
Rating
Package Group
TPS54240 TPS54040A TPS54140A TPS54240-Q1 TPS54340 TPS54341 TPS54540 TPS54541
3.5     3.5     3.5     3.5     4.5     4.5     4.5     4.5
42     42     42     42     42     42     42     42
0.8     0.8     0.8     0.8     0.8     0.8     0.8     0.8
39     39     39     39     41     41     41.1     41
2.5     0.5     1.5     2.5     3.5     3.5     5     5
1     1     1     1     1     1     1     1
100     100     100     100     100     100     100     100
2500     2500     2500     2500     2500     2500     2500     2500
0.138     0.116     0.116     0.138     0.146     0.152     0.146     0.152
Enable
Frequency Synchronization
Light Load Efficiency
Power Good
Tracking
UVLO Adjustable
Enable
Power Good
Tracking
UVLO Adjustable
Enable
Power Good
Tracking
UVLO Adjustable
Enable
Power Good
Tracking
UVLO Adjustable
Enable
UVLO Adjustable
Enable
Power Good
Tracking
UVLO Adjustable
Enable
UVLO Adjustable
Enable
Power Good
Tracking
UVLO Adjustable
Current Mode     Current Mode     Current Mode     Current Mode     Current Mode     Current Mode     Current Mode     Current Mode
98     98     98     100     98     98     98     98
-40 to 125     -40 to 125     -40 to 125     -40 to 125     -40 to 125     -40 to 85     -40 to 125     -40 to 85
Catalog     Catalog     Catalog     Automotive     Catalog     Catalog     Catalog     Catalog
MSOP-PowerPAD
VSON
MSOP-PowerPAD
VSON
MSOP-PowerPAD
VSON
MSOP-PowerPAD
VSON
SO PowerPAD     WSON     SO PowerPAD     WSON
方框图 (1)
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
