TPS53314是一款具有集成型MOSFET的D-CAP™模式,6A同步开关。该器件专为实现易用性,低外部组件数和小型封装电源系统而设计。
该器件具有单轨输入支持能力,一个20-mΩ和一个7.5-mΩ集成型MOSFET,1%准确度,0.6 V基准以及集成型升压开关。部分具有竞争力的特性包括:> 96%的最大效率,3 V至15 V的宽输入电压范围,用于实现超快的瞬态响应的D-CAP™模式控制,可选的自动跳跃和PWM操作方式,内部软启动控制,可调频率且无需补偿。
转换输入电压范围为3 V至15 V,电源电压范围为4.5 V至25 V,而输出电压范围则为0.6 V至5.5 V。
TPS53314采用5 mm×7 mm 40引脚QFN封装,并具有-40°C至85°C的规定温度范围。
<小> 小>
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS53314 | TPS53310 | TPS53311 | TPS53315 | TPS53321 |
| 3 | 2.9 | 2.9 | 3 | 2.9 |
| 15 | 6 | 6 | 15 | 6 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
| 5.5 | 4.2 | 4.2 | 5.5 | 4.2 |
| 6 | 3 | 3 | 12 | 5 |
| 1 | 1 | 1 | 1 | 1 |
| 250 | 1100 | 1100 | 250 | 1100 |
| 1000 | 1100 | 1100 | 1000 | 1100 |
| 0.32 | 0.32 | 0.32 | 0.32 | 0.32 |
| Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification |
| D-CAP | Voltage Mode | Voltage Mode | D-CAP | Voltage Mode |
| 90 | 99 | 99 | 90 | 99 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN | VQFN | VQFN | VQFN | VQFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
