数据:
TPS54260-Q1 3.5-V to 60-V Step-Down Converter
With Eco-mode™ 数据表
TPS54260-Q1器件是一款60V,2.5A,降压型稳压器,集成了高端MOSFET。电流模式控制提供简单的外部补偿和灵活的元件选择。低纹波脉冲跳跃模式可将无负载,稳压输出电源电流降至138μA。使能使能引脚时,当使能引脚为低电平时,关断电源电流降至1.3μA。
欠压锁定在内部设置为2.5 V,但可以通过使能引脚增加。输出电压启动斜坡由慢启动引脚控制,也可配置为排序和跟踪。漏极开路电源良好信号表示输出在标称电压的94%至107%范围内。
宽开关频率范围可以优化效率和外部元件尺寸。在过载情况下,频率折返和热关断可保护器件。
TPS54260-Q1采用10引脚耐热增强型HVSSOP和10引脚3 mm×3 mm VSON封装。 /p>
全部商标是其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54260-Q1 | TPS54240-Q1 | TPS57040-Q1 | TPS57060-Q1 | TPS57140-Q1 | TPS57160-Q1 |
| 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| 60 | 42 | 42 | 60 | 42 | 60 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 58 | 39 | 39 | 58 | 39 | 58 |
| 2.5 | 2.5 | 0.5 | 0.5 | 1.5 | 1.5 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.138 | 0.138 | 0.116 | 0.116 | 0.116 | 0.116 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 100 | 100 | 100 | 98 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
