数据:
LM25088, LM25088-Q1 Wide Input Range Non-Synchronous Buck Controller 数据表
LM25088高压非同步降压控制器具有所有必要的功能,可使用最少的外部元件实现高效的高压降压转换器。 LM25088可配置为在4.5 V至42 V的超宽输入电压范围内工作。这款易于使用的控制器包括一个电平转换栅极驱动器,能够控制外部N沟道降压开关。该控制方法基于利用仿真电流斜坡的峰值电流模式控制。仿真控制斜坡的使用降低了脉冲宽度调制电路的噪声灵敏度,允许可靠地控制高输入电压/低输出电压应用中所需的非常小的占空比。 LM25088的开关频率可在50 kHz至1 MHz范围内编程。
LM25088有两种版本:LM25088-1提供+ /?? 5%频率抖动功能,可降低传导和辐射EMI LM25088-2提供多功能重启定时器,用于过载保护。其他功能包括低压差偏置稳压器,控制关断和待机模式的三电平使能输入,软启动和振荡器同步功能。该器件采用耐热增强型HTSSOP-16引脚封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| LM25088-Q1 | LM25088 | LM5088 | LM5088-Q1 | LM5116 |
| 4.5 | 4.5 | 4.5 | 4.5 | 6 |
| 42 | 42 | 75 | 75 | 100 |
| 1.205 | 1.205 | 1.205 | 1.205 | 1.215 |
| 40 | 40 | 70 | 70 | 80 |
| 10 | 10 | 10 | 10 | 20 |
| 1 | 1 | 1 | 1 | 1 |
| 1 | 1 | 1 | 1 | 1 |
| 50 | 50 | 50 | 50 | 50 |
| 1000 | 1000 | 1000 | 1000 | 1000 |
| 3.2 | 3.2 | 3.8 | 3.8 | 4.6 |
| Enable Frequency Synchronization | Enable Frequency Synchronization | Adjustable Current Limit Enable Frequency Synchronization Spread Spectrum | Adjustable Current Limit Enable Frequency Synchronization | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable |
| 95 | 95 | 100 | 100 | 98 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 150 |
| Automotive | Catalog | Catalog | Automotive | Catalog |
| HTSSOP | HTSSOP | HTSSOP | HTSSOP | HTSSOP |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
