数据:
TPS6229x-Q1 1-A Step Down Converter in 2-mm ×
2-mm SON Package 数据表
TPS6229x-Q1是一款高效的同步降压型降压转换器,针对汽车低输入电压应用进行了优化,可提供高达1000 mA的输出电流。输入电压范围为2.3 V至6 V,输出电压精度为1.5%,该器件可为各种汽车应用提供动力。
TPS6229x-Q1工作在2.25MHz固定开关频率,进入省电模式工作,在轻负载电流下典型静态电流为15μA,以在整个负载电流范围内保持高效率。
省电模式针对低输出电压纹波进行了优化。对于低噪声应用,可以通过将MODE引脚拉高来强制器件进入固定频率PWM模式。在关断模式下,电流消耗降至1μA以下。 TPS6229x-Q1允许使用小型电感器和电容器来实现小尺寸解决方案。
TPS6229x-Q1采用2 mm×2 mm 6引脚SON封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62293-Q1 | TPS62242-Q1 | TPS62260-Q1 | TPS62290-Q1 | TPS62590-Q1 |
| 2.3 | 2 | 2 | 2.3 | 2.5 |
| 6 | 6 | 6 | 6 | 6 |
| 1.8 | 1.2 | 0.6 | 0.6 | 0.75 |
| 1.8 | 1.2 | 6 | 6 | 6 |
| 1 | 0.3 | 0.6 | 1 | 1 |
| 1 | 1 | 1 | 1 | 1 |
| 2250 | 2250 | 2250 | 2250 | 2000 |
| 2250 | 2250 | 2250 | 2250 | 2500 |
| 0.015 | 0.015 | 0.015 | 0.015 | 0.015 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 105 | -40 to 115 | -40 to 105 -40 to 85 | -40 to 105 -40 to 85 | -40 to 105 |
| Automotive | Automotive | Automotive | Automotive | Automotive |
| WSON | SOT-23-THIN | SOT-23-THIN WSON | WSON | WSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
