数据:
LM21215A 15-A Ultra High-Efficiency Synchronous
Buck Converter With Frequency Synchronization 数据表
LM21215A是一款同步降压DC-DC转换器,可在输出电压低至0.6 V时提供高达15 A的输出电流。 LM21215A的电压范围为2.95 V至5.5 V,具有超高效率,适用于各种低压系统。具有高增益带宽误差放大器的电压模式控制环路具有高抗噪性,窄占空比能力,可轻松补偿任何类型输出电容的稳定工作,提供最大的灵活性和易用性。
LM21215A具有内部过压保护(OVP)和逐周期过流保护(OCP),可提高系统可靠性。精密使能引脚和集成UVLO允许对器件的开启进行严格控制和排序。启动浪涌电流受内部固定或外部可调软启动电路的限制。集成开漏PGOOD指示器提供故障报告和电源排序。
其他功能包括辅助电压轨跟踪,单偏启动到预偏置负载,以及开关频率同步到300 kHz和300 kHz之间的外部时钟信号。 1.5 MHz用于差拍频率敏感和多稳压器应用。 LM21215A采用耐热增强型20引脚HTSSOP封装,裸露焊盘焊接在PCB上,实现了极低的结至电路板热阻抗。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM21215A | LM21212-1 | LM21212-2 | LM21215 |
| 2.95 | 2.95 | 2.95 | 2.95 |
| 5.5 | 5.5 | 5.5 | 5.5 |
| 0.6 | 0.6 | 0.6 | 0.6 |
| 15 | 12 | 12 | 15 |
| 1 | 1 | 1 | 1 |
| 300 | 300 | 300 | 500 |
| 1500 | 1500 | 1500 | 500 |
| 1.5 | 1.5 | 1.5 | 1.5 |
| Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
