TPS6267x器件是针对小型电池供电应用而优化的高频同步降压DC-DC转换器。 TPS6267x专为低功耗应用而设计,可支持高达650 mA的负载电流,并允许使用低成本芯片电感和电容。
具有2.3V至4.8V的宽输入电压范围,该器件支持由具有扩展电压范围的锂离子电池供电的应用。不同的固定电压输出版本可在1.05V至2.1V之间使用。 TPS6267x以6 MHz的稳定开关频率工作,并在轻负载电流下进入省电模式,以在整个负载电流范围内保持高效率。
PFM模式通过在轻负载操作期间将静态电流降至17μA(典型值)来延长电池寿命。对于噪声敏感应用,该器件具有PWM扩频能力,可提供较低的噪声调节输出,以及输入端的低噪声。这些特性与高PSRR和交流负载调节性能相结合,使该器件适合替代线性稳压器,以获得更好的功率转换效率。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62671 | TPS62125 | TPS62175 | TPS62230 | TPS62740 | TPS62742 | TPS62745 | TPS62746 | TPS62748 | TPS62821 |
| 2.3 | 3 | 4.7 | 2.05 | 2.2 | 3 | 3.3 | 2 | 2.15 | 2.4 |
| 4.8 | 17 | 28 | 6 | 5.5 | 5.5 | 10 | 5.5 | 5.5 | 5.5 |
| 1.8 | 1.2 | 1 | 2.5 | 1.8 | 1.8 | 1.8 | 1.2 | 1.2 | 0.6 |
| 1.8 | 10 | 6 | 2.5 | 3.3 | 3.3 | 3.3 | 3.3 | 1.8 | 4 |
| 0.5 | 0.3 | 0.5 | 0.5 | 0.3 | 0.4 | 0.3 | 0.3 | 0.3 | 1 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 5400 | 1000 | 1000 | 2000 | 2000 | 2000 | 2500 | 1200 | 1200 | 2200 |
| 6600 | 1000 | 1000 | 3000 | 2000 | 2000 | 2500 | 1200 | 1200 | 2200 |
| 0.017 | 0.013 | 0.0048 | 0.022 | 0.0003 | 0.0003 | 0.0004 | 0.0003 | 0.00036 | 0.004 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Spread Spectrum Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Dynamic Voltage Scaling Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Load Disconnect | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification |
| Voltage Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| DSBGA | WSON | WSON | SON | WSON | WSON | WSON | DSBGA | DSBGA | VSON-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
