数据:
12A High Efficiency Synchronous Buck Regulator w/Adjustable Switching Frequ(cn) 数据表
LM21212-2是一款单片式同步降压稳压器,能够提供高达12A的连续性输出电流同时产生低至0.6V的输出电压,效率极高。该器件经过优化,可在2.95V至5.5V的输入电压范围内工作,适用于各种低压系统。电压模式控制环路具有高抗噪性,窄占空比能力,可以通过任何类型的输出电容进行补偿,从而提供最大的灵活性和易用性。
LM21212-2具有内部过压保护(OVP)和过流保护(OCP),可提高系统可靠性。精密使能引脚和集成UVLO允许对器件的开启进行严格控制和排序。启动浪涌电流受内部固定和外部可调软启动电路的限制。集成电源良好电路可实现故障检测和电源排序。
LM21212-2设计用于多轨电源架构。器件的输出电压可配置为使用SS /TRK引脚跟踪外部电压轨。开关频率可通过外部电阻在300 kHz和1.55 MHz之间编程。
如果输出在启动时预偏置,它将不会吸收电流,使输出平滑地上升超过预偏置电压。该稳压器采用20引脚eTSSOP封装,带有裸露焊盘,可焊接到PCB上,无需使用笨重的散热器。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM21212-2 | LM21212-1 | LM21215 | LM21215A |
| 2.95 | 2.95 | 2.95 | 2.95 |
| 5.5 | 5.5 | 5.5 | 5.5 |
| 0.6 | 0.6 | 0.6 | 0.6 |
| 12 | 12 | 15 | 15 |
| 1 | 1 | 1 | 1 |
| 300 | 300 | 500 | 300 |
| 1500 | 1500 | 500 | 1500 |
| 1.5 | 1.5 | 1.5 | 1.5 |
| Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
